I was pulling a 26ft trailer loaded and unloaded and it did this both times. As i started to go up a hill at 60 mph it was in overdrive and about half way up it started to make a noise , the only other time i have heard this noise is at truck and tractor pulls when they cant pull any futher they have a weird turbo sound. My truck never down shifted but when i heard that noise i started to get woried and let off. I dident have overdrive locked out because i dont like running 2500 and up rpms for long periods of time. Is that normal or is something wrong? Thanks for any help
I have a 2001 7.3 and i have an edge tuner but i have it on the stock setting when towing big trailers and i have a 5 in turbo back pipe. And i have an autometer boost gauge.
it almost sounded like a surging and my boost gauge was flickering ,not a lot but enough. i can still hit 21 psi boost, this all happend around 16 psi boost.
Can you describe the noise? Was it a steady or pulsing sound? If it was a pulsing type sound, we need one of the guys who has a link to the clip of turbo surge handy. If it's just a loud steady sound, or a high pitch whistle, it's probably not an issue. Did your boost gauge flutter when the noise was happening? What boost psi were you reading when this happened?
If it was a "chuffa-chuffa-chuffa" or "psst-psst-pssst" sound with a fluttering gauge, you were surging. Common issue, especially with a stock turbo while towing with tunes. Mine did that empty on my hot tunes.
Another vote for the possible surging, I had it too with my stock turbo. He said his gauge was flickering, isn't that one of the warning signs of surge??
I would say surge. Add an intake mod and get some more air in there. Maybe try the wiked wheel. I have one if you need one. Pm me if you are interested.
You can eliminate that surging by installing an early style intake wheel or a vented housing.
I went with the wheel because it was a lot less expensive than the vented housing and it has a cool whistle sound to boot.
It's commonly known as the Wicked Wheel.
