Hutch Mod Concerns
Old Oct 8, 2009 | 04:19 PM
jkidd_39's Avatar
jkidd_39
Originally Posted by SpringerPop
It sounds like you are saying that "someone" is doubting the benefits of a pre-pump filter. If that's the case, I'll take issue with him on this.
I use a Dahl-100 as my pre-pump, and have not had a fuel delivery problem for the entire time it's been installed, about 65,000 miles.
I do not have any horsepower-enhancers, so do not have inordinately high fuel demands, but I also filter it there to two microns, with a corresponding significantly-higher restriction.
I believe the Baldwin BF1212 to be a very good filter, and if I were to do it over again would likely choose it over the Dahl, especially for ease of element change.
In my opinion, there's not a significant-enough restriction in any of the commonly-used pre-pump filters to affect the pump's performance to warrant elimination, and there's a real problem that can develop at the pump's input screen if you do.
Pop
One of the brothers on here offered to sell me a Dahl 100 filter set-up.
Where are you getting filters from? If in a pinch I know I could go to Napa or O'Reilly's for filters.
How difficult are the element changes? The Dahl is much more expensive than a Ballwin set-up.
Thanks all!
Old Oct 8, 2009 | 05:10 PM
spdmpo's Avatar
spdmpo
Originally Posted by WA.Ranger
Well Andrew I have that setup plus a Carter pump. I have 66lbs. of preasure measured at a "T" on my return line. I have 180k on my stock fuel pump and about 4k running the prefilter. Not long enough to give you any kind of hard data, but I wouldn't do it any other way.
I'm using this same set up with the Carter helper pump between the factory pump and the Baldwin filter. IMO it's never a good idea to not have a filter before any pump, and I really wasn't going to put the pump between the tank and filter and have to add yet another filter to protect the lift pump. I really don't have much to add because I did not take any fuel pressure readings before or after the ITP/Hutch mod. What I can tell you is that the day I did it, my fuel pump quit on me. Whether it was from dirt, being overworked, coincidence, or just that last straw on a 170,000 mile pump remains unknown. After replacing the pump I added the Carter lifter pump and have been fine ever since. I have no idea if I need it or not, but I have peace of mind. I feel no difference in power with or without it btw.
Old Oct 8, 2009 | 06:25 PM
SpringerPop's Avatar
SpringerPop
Thanks all!
I bought a case of two-micron elements off eBay before I installed the Dahl, and at the rate I'm using them, I have a lifetime supply. I'll likely never buy another. I would think that a marine (boating) supply would have them, as they are quite commonly used on diesel-powered boats. The auto-parts houses will likely not have them in stock.
Changing the element is more complicated than just changing a spin-on and takes more time, but it filters smaller particles, so I believe it's worthwhile to put up with the greater hassle.
Pop
CousinCarl
83
Oct 10, 2019 06:16 AM
Jointasset
Mar 13, 2016 09:18 AM
bflora
28
Mar 26, 2014 06:01 PM
BWST
Jan 10, 2013 10:14 AM
joeyd61
May 9, 2012 05:57 PM
