Sponsored by: Real Truck
TorqShift Transmission Flush Question
Old Jan 1, 2010 | 06:07 PM
  #31
FoxNotch's Avatar
FoxNotch
Originally Posted by bpounds
No. Mercon V is available just about anywhere in many brands. Mercon SP is Motorcraft only and costs more.
You do NOT want Mercon V in your Torqshift.
Oh alright.
I saw someone earlier in this thread mention that mercon sp was $3 and change at a local store, and I remember mercon V being $5-6 when I was in a pinch and had to buy it at autozone. Maybe that's a knock-off SP?
Never the less, I'm gonna get the dealer service, and I'll make sure everything is done right (neighbor is a saleman there).
Old Jan 1, 2010 | 06:19 PM
  #32
sandmanf250's Avatar
sandmanf250
i drain the pan and put new toilet paper in along with 8 qts mercon s-p twice a year . 164,000 and working perfectly.
Old Jan 1, 2010 | 08:54 PM
  #33
Tom's Avatar
Tom
I mentioned the cheap Mercon SP. It's Motorcraft fluid but it's very tough to find outside a dealer. Dealers want $6-8 a quart for the stuff!
Mercon V is available from a variety of manufacturers and is even marketed in wal-mart's store brand! Cheap and easy to find.
I'd also like to add that Mercon LV supercedes SP. Mercon LV is a newer fluid and is recommended in place of SP. So either one would work!
Old Jan 2, 2010 | 05:32 AM
  #34
sandmanf250
it's not a replacement for s-p
Old Jan 2, 2010 | 09:36 PM
  #35
Tom's Avatar
Tom
Yes, it is.
Ford Special Service Message 21114
REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND 2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP. THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
EFFECTIVE DATE: 11/26/2009
Mercon LV and SP - Page 2 - Ford Truck Enthusiasts Forums
Sorry for not quoting my source earlier!
Old Jan 3, 2010 | 05:21 AM
  #36
Furian's Avatar
Furian
You Keep What You Kill
I believe he is stating that Mercon V is not a substitute for Mercon SP...
Old Jan 3, 2010 | 01:48 PM
  #37
bpounds's Avatar
bpounds
Yes, it is.
The latest memo from Ford notwithstanding, this is a very recent development, and as of today the Motorcraft LV product page has not been updated:
http://www.fcsdchemicalsandlubricant...smission Fluid
"Do not use in applications where MERCON® V, MERCON® SP, Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended, or in transfer cases."
I guess they are testing this theory on US. And as long as they still make SP, that's what I want in my transmission. When they have the ***** to discontinue SP, then I will know that LV is okay.
Old Jan 4, 2010 | 09:07 PM
  #38
06DEUCERIDER's Avatar
06DEUCERIDER
Maybe I missed something, please explain if so. I have a 2006 Powerstroke F250 with the 5R110 Torqshift. Just did my first fluid change. Initially I removed the rear line and installed the clear tubing, fluid pumped out of the transmission, it was not the return line.
Old Jan 5, 2010 | 03:46 AM
  #39
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The rear line IS the return line. If you were getting very little flow out of that line the problem was that the trans wasn't hot enough. The TorqShift has a thermostat that cuts the flow to the coolers by 90% when the trans is below 165°F. You need to have the trans warmer than that for the entire time you're doing the flush or it will just mix the old and new fluids instead of flushing out the old fluid.
Old Jan 5, 2010 | 09:45 AM
  #40
DavidB's Avatar
DavidB
Transmission Fluid Chart
Automatic Transmission Fluid Chart
Old Jan 5, 2010 | 11:03 AM
  #41
06DEUCERIDER
OK Mark, so then was it just static pressure that caused the fluid to be pumped out the return port on the tranny? When I started this a little, maybe a quart, of fluid came out the tubing attached to the rear line but about a gallon pumped out of the tranny port. Also, if fluid is pumped from the tranny to the remote external filter, and temperature depending on through the cooler, wouldn't a person be able to get 90-95% of the old fluid out by just letting the fluid escape at the filter housing up front. I ask because I did this after my issue with removing the return line.
Old Jan 5, 2010 | 11:06 AM
  #42
06DEUCERIDER
David B.,
I appreciate the chart, but as long as MERCON SP is available I'll be putting that in mine (per the owner's manual). I ask if there was any OK substitute at the dealership, since that is the only place selling SP here, and they said no; including LV fluid. They may be wrong, but need to find out at the moment.
Thanks though
Old Jan 5, 2010 | 01:08 PM
  #43
Furian's Avatar
Furian
Mark, can you provide a step-by-step procedure that should be used to properly flush the ATF in the Torqshift transmission? I would like to have that information to compare to the procedure used by my local Ford dealership and/or other shop in my area. I'm hoping that this procedure is one that I can do myself to ensure that all of the ATF is replaced. Thanks!
Old Jan 5, 2010 | 05:52 PM
  #44
Mark Kovalsky
With the thermostat closed there is still flow to the cooler. It's 10% of the open thermostat flow.
No, I can't. I've never flushed a TorqShift and I don't have one to experiment on.
Old Mar 11, 2010 | 11:56 AM
  #45
4x4given's Avatar
4x4given
Thanks to all for the info and pointers.
After reading this thread and some others and doind some more research on this topic. I decided that properly flushing mine at home was just too much a PITA vs the cost at the local Ford dealer.
I called them and they quoted me $189 (using Mercon SP, I expect LV will be a little cheaper). They use heated machine flush, which uses the transmission's pump (so no undue pressures are created that might damage the transmission) and they will use Mercon LV if I want that (and I do). Made an appointment for Saturday morning. They said it should take about 1 - 1.5 hours.
Personally, I have a *VERY STRONG* aversion to anybody touching my truck, bikes, cars etc (I was a mechanic for a little more than 20 years). So I will go back over all connections and recheck levels when they are done and make certain everything looks good.
Have a great day!
