Engine oil temp
Old Oct 6, 2009 | 12:13 AM
renyren's Avatar
renyren
Engine oil temp
I was wondering what the normal operating engine oil temp is. This weekend while towing up a grade it climbed to 216 and the AC stopped blowing cold. As soon as I got to the top of the hill temps droped back down to about 197-200 and the AC started blowing cold again. Is this normal? My trailer is only about 6000 lbs. My truck is a 2000 Crew cab 7.3L diesel with 4inch lift 35 inch tires and DIY napa 6637 filter and zoodad mod.
Old Oct 6, 2009 | 12:19 AM
Layson's Avatar
Layson
216 isn't a problem at all. That sounds normal. At like 240-260 the pcm starts to limit ICP.
How are you monitoring it?
Old Oct 6, 2009 | 08:12 PM
renyren's Avatar
renyren
with a scan gauge II. what about the AC not blowing cold untill it startes cooling down, is that normal?
Old Oct 6, 2009 | 08:27 PM
bdrummonds's Avatar
bdrummonds
Actually at 215* (EOT) the fan clutch kicks in and starts pulling more air through the radiator. When this happens the PCM disengages the compressor clutch on the AC. It all happens within preset parameters that the PCM takes from the EOT(engine oil temp) sensor, the EBPS (exhaust back pressure sensor) and of course the spring inside the fan clutch expanding and engaging due to heat.
So, yes, it is normal.
Old Oct 6, 2009 | 09:57 PM
Izzy351's Avatar
Izzy351
I have the 192* 'stat, and I've never seen my EOT above that. But I'm not towing either...
Pitcrw6
May 1, 2025 08:07 AM
jeffrey5679
May 8, 2013 09:29 AM
rpbfixit
Jul 30, 2012 11:20 AM
Utah Jake
Jul 25, 2011 02:37 PM
ghunt
28
Dec 12, 2008 08:47 PM
