Sponsored by: Real Truck
AC Weird
Old Jul 25, 2011 | 12:22 AM
Utah Jake's Avatar
Utah Jake
AC Weird
2006 F350 6.0 Powerstroke. Towing my 5th wheel, going flat roads, AC normal but as I climb hills, I start loosing cool air and it starts blowing warmer. The water and oil temps stay within 15 degrees of each other ( ECT 230 max - EOT 247 max). It seems the warmer the engine oil temp, the warmer the AC. Cool air recovers as I go down the hill and EOT cools.
I checked and the AC condenser is in front of everything. Just can't figure this one out.
Old Jul 25, 2011 | 12:32 AM
the almighty schmuck's Avatar
is the a/c on auto ? mine does similar thingwheni have it set toauto but not when i tell it which vent to come from
Old Jul 25, 2011 | 12:33 AM
damn i need a new keyboard frigging spacebar never working
Old Jul 25, 2011 | 02:09 AM
hotroddsl's Avatar
hotroddsl
The PCM is using your heater to help cool the engine? That's the only logical explanation I can come up with! Monty is wagging his approval so I must be right....lol
Jim...& fat Monty
Old Jul 25, 2011 | 09:50 AM
dchamberlain's Avatar
dchamberlain
230 is hotter than I think I'd be comfortable with. I think I'd check that out as well.
Try using Max A/C. That will close off the coolant flow to the heater core. That might make a small difference.
The only other thing I can think of is that the PCM is shutting the A/C compressor off above a certain coolant temp to try get cooler air over the radiator.
You might get better answers in the 6.0L Diesel forum.
Old Jul 25, 2011 | 09:57 AM
dchamberlain
Is your fan coming on? At 230 degrees it should sound like a jet is taking off under the hood.
Old Jul 25, 2011 | 02:37 PM
Utah Jake's Avatar
Utah Jake
1) The fan was coming on at the right temp.
2) I tried it in manual, no change.
really strange, I can't see the connection between the hills and AC. Not a loose of vac closing mixing doors since a diesel has a stand alone electric vac pump.
I will try max AC next time but I thought that just had to do with fresh air vs cab air.
Niki Farmgirl
Jun 9, 2018 06:21 AM
ij72
Jun 26, 2014 06:31 AM
davefishguy
Aug 14, 2013 06:06 PM
tealboy1
Aug 12, 2005 10:52 AM
tealboy1
Sep 28, 2003 11:32 PM
