Rear A/C blowing warm and front blowing cold
The front a/c blows cold air but the 2nd row and back blows warm. Yes the temp dial is on cold on both dials. Is there a separate a/c clutch that I dont know about to ck the air gap? Is there a separate port to put freon in besides the front. I need to get this fixed because with my bulldogs in the back the heat will kill them.
on
The rear has a Thermostatic Expansion Valve (TXV) to meter the flow of refrigerant into the rear evaporator. When the TXV goes bad the rear will not cool. The TXV is accessible in the jack compartment in the rear passenger side of the vehicle. The TXV is a rectangular block with four refrigerant lines attached to it. The entire system has to be evacuated and recharged in order to replace the TXV.
The following users liked this post:
My black Excursion had that problem, but I never did figure it out. The front never seemed to be a true cold though- it wouldn't be the usual 40 or so degree air that comes out when you set the temp down to 60. I added some refrigerant and the system seemed to be pressurized fine, the front did the colder, but the back was never fixed.
It got to the point that the front air couldn't cool it down regardless on the 85+ degree day. Of course being black didn't help, but it should have made it bearable in there after a half hour.
The refrigerant has to be weighed in or there is no way you can be sure it is charged correctly. Mine had the warm AC in the back when I bought it last year, till I pulled it down and charged it. It works great since then.
My sisters X was all plugged up at the orifice tube, there is a strainer there that catches all the junk in the system. On hers the rear TXV was plugged up, IIRC it was 45 bucks, they didn't have the money so I just vacuumed and recharged it. The front has been working great after that. It will cool the entire vehicle now.... Not as good as mine does with the rear ac cranked, but still livable. This was after I rode in the back to a ball game after the local shop had "fixed" it. I felt bad for my nieces and nephew after riding back there and told him to come see me and bring the $2 orifice tube and I would do it for free..... gotta love family.
on
Any local garage can evacuate (and check for leaks at the same time) and recharge it and you can replace that valve first yourself. You might save hundreds. Ford wants $1000 just to put a new rear AC line in.
on
They are just a simple block on the Ex.
http://www.ebay.com/itm/MOTORCRAFT-YG-359-A-C-Expansion-Valve-/360501962707?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AExcursion&hash=item53ef9767d3&vxp=mtr
Since you are pulling open the AC lines I would replace the orifice tube also, that will give you an idea as to what kind of condition your rear AC is in. If it has junk in it you can be sure that there is junk in the back line set too and it needs to be flushed after you remove the old TXV and install the new one or it will just plug up again.
on
The orifice valve is cheap and it's up near the front condenser. They have a long screen that filters any junk in there and are usually OK unless your compressor goes out. I didn't even look at mine when I fixed my rear AC line and it's fine but they will tell the story about the condition of the system.
