Poor aceleration
Old Oct 5, 2009 | 05:37 PM
Jetmx's Avatar
Jetmx
Poor aceleration
My truck is slow to acelerate. I got a check engine light with a code of P2262. I dont have a book to tell me what the fault is. When I acelerate, my factory dash boost gauge shows little to no indication. I'm barely under my 100k warranty. Anybody have any ideas or quick cures or things to try before I take it in?
Thanks ahead,
chet
Old Oct 5, 2009 | 05:52 PM
bismic's Avatar
bismic
Check to see if your MAP sensor hose is disconected or has a hole in it. Also, check for CAC system leaks or intake/exhaust leaks.
Old Oct 6, 2009 | 09:02 PM
Jetmx's Avatar
Jetmx
Thanks for the reply & suggestions. I only have a Hayes manual & it doesnt show the location of the MAP sensor on the 6.0. I'm going to keep looking. I have a factory service manual on CD that I bought on Ebay but it will not open up.
I also found the fault code list on this forums FAQ but the numbers dont go that high. Would you know what that fault code is?
Old Oct 6, 2009 | 09:36 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 655pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=873 x:str><COLGROUP><COL style="WIDTH: 655pt; mso-width-source: userset; mso-width-alt: 31926" width=873><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: silver; WIDTH: 655pt; HEIGHT: 12.75pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 1pt solid" class=xl24 height=17 width=873>MAP Sensor</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: silver; HEIGHT: 12.75pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>http://dan.prxy.org/Truck/6L_bible_h.../Page_038.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: silver; HEIGHT: 12.75pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>http://dan.prxy.org/Truck/6L_bible_h.../Page_063.html</TD></TR></TBODY></TABLE>
The MAP sensor mounts under a triangular bracket that is "to the left" of your heater control valve (coolant flow to the heater core). It is near the firewall. The MAP sensor hose (rubber hose w/ a corrugated plastic heat shield around it) connects to a port on the right (passenger's) side intake manifold. I took the hose off and blew air through it.
joshinthe586
2004 - 2008 F150
32
Jul 7, 2018 08:31 PM
Little General
2009 - 2014 F150
Dec 1, 2015 02:44 PM
wheelchairdude49
1983 - 2012 Ranger & B-Series
36
Oct 15, 2015 09:02 AM
d&tperformance
Mar 15, 2012 12:22 PM
Fishin76
2004 - 2008 F150
Sep 12, 2007 09:46 AM
