Ford Ranger 4R44e trans shifting problems
Is the tanny fluid level & fluid condition ok???? Has it ever had a complete fluid & filter change out????
If the tranny fluid & filter have never been changed, I might suspect varnish or sludge deposits.
Are you having any other problems, like the speed-o, ABS, or cruise control acting up????
If so, suspect the rear ABS speed sensor, as it's output is also used by the computer to decide when to tell the tranny to shift & those other systems also use the ABS sensors output, so if any of them are showing signs of acting out, I might suspect the ABS speed sensors ouput is corrupt.
Just some things to ponder.
OK, seeing as how your well past due for schduled tranny service & the fluid level is ok & you say the fluid condition seems ok, not burned or brown looking, or sludged up, I'd maybe consider a dose of Seafoam Trans Tune, at the perscribed treat rate (don't overfill the tanny), then drive 50-100 miles & see if you get a positive response.
It's a cleaner-upper that won't get after seals, gaskets, plastic, or metal parts.
You can check it out here, if you think it may be for you. http://www.seafoamsales.com/transTuneTech.htm
If so, I'd suspect sludge and or varnish deposits in the valve body, solenoids, ext, from running past due on tranny service.
You can do the filter change & fluid pump out your self, for about $60, & a afternoon having fun in the driveway!!!! lol
Or around here, you can have a Dealer or Tranny Shop do it for about $150, BUT I'd not opt for their solvent flush part of the service, as any crud it stirs up will first have to be strained through the tranny filter, before the tranny pumps it out. Not a good idea imo.
Anyway, look at this as past due scheduled tranny maintenance, which is what it really is. Maybe it'll work, maybe not.
I suppose you could pull, or have pulled, any existing tranny computer trouble codes & go from there.
Let us know what you do & find.
Originally Posted by wheelchairdude49
just found out from the dealer the clurches or bands are going. need a rebuild
I'd still try the Trans Tune treatment for a hundred or so miles & see what happens, if it gets better, maybe drive until it stops acting out, or doesn't get any better, then do a filter change & complete tranny fluid change out.
If you don't want to try that, I'd at least get a second, or maybe a third opinion, before opting for a Dealer rebuild.
If you do go with the Dealer rebuild, have them put in writing what it'll cost & that the rebuild will fix your problem, BEFORE you let them tear into it.
Let us know how it goes.
2000 ranger shifting problems
-well i took it to a trans shop this week and had the fluid and filter changed. I did see metal. in the pan never drove it low on fluid never had to add any. Ive only put 18,00 in the 5 yeaqrs that ive owned it. no bur outs either lol. hard to do with hand controls on the truck. im 2 months out of warranty and called ford to see if they could help me. they said i had to take it to a ford dealer before they made their decision. hope they cover it.
Well burned fluid & metal in the pan isn't good news, the Dealer may be right!!!!
How much & what kind of metal???
Some dark colored clutch friction grit material in he bottom of the pan is normal, chunks of metal arent.
I'll ask again, what color was the fluid????
Was it thick & brown & smell burned????
Did it still have any red color????
Did they do a full tranny flush, to remove ALL the old fluid, or just a drop the pan, replace the filter & refill the pan, service????
If it was a complete fluid change out & it's doing better, maybe give it a while for the new fluids detergents to do their thing.
If it doesn't stop acting out, or they didn't do a complete fluid change out, maybe try the Seafoam Trans Tune & see if maybe it'll help tidy up deposits, like gum, varnish & sludge that may be sticking the solenoids up.
So maybe between the new fluid & a dose of Seafoam Trans Tune, you could clean things up enough, for it to last a little while longer, but from what you've posted, it's likely gonna need more in the long run, than a transfusion!!!!
Cddz may be right, it might have valve body gasket leak problems too, as they are commom on this tranny.
Did the tranny shop guys say anything about the valve body when they were servicing the filter????
Good luck with te warranty folks, cause they will likely want to see evidence of timely scheduled maintenance, sobe prepaired to present dated reciepts!!!!!!
I heard the wheel chair burn-out part. lol
You get into any of the chair racing events, or sports events????
