Gas Mileage
Are you calculating it right?
Granted your speedo/ododmeter are accurate and the dual tank set up is working properly, try this: Fill up one tank until the pump shuts off automatically, stop pumping. Do the same the to the other tank. Reset trip. Drive until its time to refuel. For best results, use the same gas pump and repeat the fill up. Now take the miles driven, and divide by the gallons just pumped. There's your overall MPG.
Then try one tank at a time to see if the numbers match up.
That works on single tank cars, and I would assume it would work on a dual tank set up...
I tried the calculating thing a few times and each time I get less MPG on the rear tank.BTW the rear tank pump was changed by the Ford dealer about two months ago because it quit but I had this problem before that.They also checked to see if the rear tank was transfering to the front tank.
oceanair
06-04-2001 08:26 PM
RogerW
11-10-2000 10:23 AM
RogerW
06-30-2000 06:54 AM
