wiper
Old Oct 5, 2009 | 11:29 AM
bfbiker's Avatar
bfbiker
wiper
Oks anyone know where to find the wiper relay under the dash ,0n a 92 f150 custom.mine works only on fast and slow and 2 speeds below slow
Also what year buckets will fit my 92 custom
Old Oct 5, 2009 | 12:24 PM
rla2005's Avatar
rla2005
Assuming you have intermittent wipers; what you describe is a very common problem. The variable speed control gets clogged with dirt/extra grease. It is fairly easy to take apart, clean it up and re-assemble. If I recall correctly there is a small allen screw on the ****, it is easier to see if looking from the floor level. Take the screw out, but be careful there is a spring and pin behind it. A real joy to find when it shoots out unexpectedly. Once apart you can clean up the contacts then re-assemble.It took me about 20 minutes the last time I did it.
Old Oct 6, 2009 | 10:16 AM
bfbiker's Avatar
bfbiker
Talking ?
Great now where is it under the dash,whats it by about what size and color is it,Thanks
