High Exhausht pressure
Old Oct 5, 2009 | 10:53 AM
lilpro's Avatar
lilpro
When im goin up hills pulling a trailer not even anything too heavy (about 5000 pounds) , i have to down shift. I can leave it in 5 gear but then my check engine like and i check it and it says High exhaust pressure. Is there something i can do or add a mod to eliminate the problem.
I have search a little be and i didnt know if this is the "surge" problem?
specs: 02 7.3, bully dog triple dog downloader, 18k dfuser module, 5 inch exhaust, cold intake, on 37's
Old Oct 5, 2009 | 11:00 AM
rebelchevy02's Avatar
rebelchevy02
What rpms are you at when this happens? I know you said 5th gear, but what rpms? Surge is something you usually can hear, and usually in the 1500-1700rpms range.
Old Oct 5, 2009 | 11:04 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Just throwing it out there: overboost?
Old Oct 5, 2009 | 11:06 AM
Izzy351's Avatar
Izzy351
Your 37s are complicating things here. You have a 5" exhaust, but if you have a stock turbo, the exhaust housing becomes very restrictive in the high RPMs. You can get a 1.0 a/r housing or upgrade to a van turbo with a 1.15 a/r housing. The bigger housings favor higher RPMs and will reduce backpressure and EGTs.
Old Oct 5, 2009 | 01:17 PM
duck fan's Avatar
duck fan
Because racetruck
How about cleaning the EBPS tube?
Old Oct 5, 2009 | 03:03 PM
Izzy351's Avatar
Izzy351
Then he'd have low EBP if it was restricted/plugged.
Old Oct 6, 2009 | 10:14 AM
lilpro's Avatar
lilpro
What is EBP
Old Oct 6, 2009 | 10:18 AM
rebelchevy02
Exhaust back pressure sensor. Located on the front of your motor, between the HPOP and the engine fan.
Old Oct 6, 2009 | 10:22 AM
Izzy351's Avatar
Izzy351
EBP = Exhaust Back Pressure
EBPS = Exhaust Back Pressure Sensor
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by lilpro
What is EBP
Here is a link so you get the idea. click here
Old Oct 6, 2009 | 10:38 AM
lilpro's Avatar
lilpro
k, thank you. Is there a certain housing you would recommend? Planing on getting a bigger horse trailer, and also a toy hauler for two trucks.
Old Oct 6, 2009 | 10:51 AM
Nick 99's Avatar
Nick 99
If the EBP tube had a small leak, it would give you the symptoms you are experiencing.
Old Oct 6, 2009 | 10:52 AM
PaysonPSD's Avatar
PaysonPSD
Make sure the EBP Valve is fully open when truck is warmed up.
Old Oct 7, 2009 | 10:18 AM
lilpro's Avatar
lilpro
So i checked the codes and i came up with the following
P0470 : Exhaust Pressure Sensor
P0238 : Turbocharger Boost/Sensor A Circuit High
So im thinking the EBPS? Clean it and check make sure it not cracked?and maybe a new turbo housing?
Thanks
Michael
Old Oct 7, 2009 | 10:38 AM
Ponyboychris's Avatar
Ponyboychris
Cleaning your EBPS is a lot cheaper route than a turbo upgrade so I would start there. Use the directions that Rick posted.
