Help
Old Oct 7, 2009 | 08:32 AM
throwdown's Avatar
throwdown
Help
My helper damaged my RR stainless HPX and it cannot be reused. I don't have time to wait for another, so I am going to have a flexible one built here.
Can anyone give me the specs and recommended hose type?
Thanks
Old Oct 7, 2009 | 09:02 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Do you still have the original plugs? I would plug the holes till I could get another.
I can't help you with the specs. Good luck.
Old Oct 7, 2009 | 10:07 AM
throwdown's Avatar
throwdown
My helper thought that the FRX replaced the HPX and chucked the parts. When we tried to recover it, it was bent and the ends missing. So, starting from scratch with the turbo off and this would be the time to replace it. A local company can make the hose if I have the specs.
Old Oct 7, 2009 | 10:30 AM
jkidd_39's Avatar
jkidd_39
For the price of a shop to build it you could call Clay at riffraffdiesel.com and order one and it would have the soft heat resistant coating.
Good Luck man
Old Oct 7, 2009 | 10:36 AM
just another truck's Avatar
just another truck
3000 PSI is wha the HPOP is supposed to run at per my ,manual. As far as the material, just let them know you are running Motor oil/synthetic oil through the hose. You should have no problem. If you do not get an answer from your hose shop, PM me, I will call mine
Old Oct 7, 2009 | 10:37 AM
throwdown's Avatar
throwdown
I got my first one from Clay. I live in Canada and it cost about $140 Canadian for that one, after import duty, shipping, and taxes. It also takes about ten days to get here if all goes well at Customs. I think that a local shop will have access to the same product. (I hope).
Old Oct 7, 2009 | 10:40 AM
throwdown's Avatar
throwdown
Thanks for the pressure rating. I need to know the fitting size as I don't have old parts to look at. I can figure the lenth from the bent one that I have.
