I hate to ask
Old Oct 4, 2009 | 07:01 PM
jimbeam&coke's Avatar
jimbeam&coke
I hate to ask
I have a 74 ford 360 4x4 that has a 2 barrel carb. I have ask a question like this before so dont shoot me just yet. I want to go to a four barrel intake and carb. A friend that has a 390 4 barrel intake with a 4 barrel carb. I dont know what it came off of but he says it will fit my truck. Is this worth it to change? Dont want to race just a little bit more power. After all what man doesn't . ps the intake and carb are free
Old Oct 4, 2009 | 07:04 PM
jimbeam&coke
The intake and carb is not performance. Cast iron like mine already. And carb is the same one that was mounted on it.
Old Oct 4, 2009 | 07:07 PM
Jermafenser's Avatar
Jermafenser
Any information on what the manifold and the carb are? Edelbrock? Etc...
Old Oct 4, 2009 | 08:56 PM
mark a.'s Avatar
mark a.
If you are going o get a 4v intake get an aluminum one. You won't believe the weight difference. You would need 2 people to put a iron one on in the vehicle.
Old Oct 4, 2009 | 09:10 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
It will work fine. The job isn't that bad if you have an engine hoist to lift the old one off and help you install the new one. However, if you have never had a hernia or a ruptured spinal disc and you want to experience what either feels like, try to do this job by yourself and without a hoist.
The nice thing about it is that you probably won't have to do much tuning on the carb to get it right, as long as it is in good shape. Just make sure that the manifold doesn't have any gunk buildup in any passages...and if it does, clean it out good with mineral spirits and wire bottle brushes before you go to all that trouble and through all those gaskets!!
You can't beat free, especially if it's something you can use!
Old Oct 4, 2009 | 09:19 PM
hotroddually's Avatar
hotroddually
you said the "F" word! (no, not THAT "F"word) free is good,but i too think you would be better off trying to get an aluminum intake. these fe blocks have the biggest intake around,so replacing the cast intake with an aluminum 4 barrel intake is a nice upgrade.its up to you. the 390 cast intake will fit if you do choose to try it.
Old Oct 4, 2009 | 09:24 PM
crazyeddie's Avatar
crazyeddie
I'd go with it whether it's a cast iron intake or not. Just the upgrade from the 2-barrel to the 4-barrel would make the swap worthit.
Old Oct 4, 2009 | 11:58 PM
Dirt racer's Avatar
Dirt racer
Just like your user name!
Old Oct 5, 2009 | 06:08 PM
jimbeam&coke
thanks
I guess i will give a shot. I dont have a hoist so its grunt and go for me. Oh well nothing comes easy in SC. Thanks for the info.
Old Oct 5, 2009 | 10:15 PM
crazyeddie's Avatar
crazyeddie
My dad says a cast iron intake weighs in the neighborhood of 50-60lbs so you don't need a hoist to get it off unless you have either a hernia or zero ***** (this is coming from my dad who wrestled a bare 351W block out of a Galaxie by hand).
Old Oct 5, 2009 | 10:31 PM
F350moneypit's Avatar
F350moneypit
I weighed my 4 barrel intake....it was 95 lbs!
granted it is the larger cast iron police interceptor / Cobra Jet type-- still these are not easy to work with.
Old Oct 5, 2009 | 10:41 PM
crazyeddie's Avatar
crazyeddie
Holy crap! Yeah 95lbs is a little tough to manipulate into place I guess!
Old Oct 6, 2009 | 06:27 PM
Pickupmanx2's Avatar
Pickupmanx2
They are HEAVY, even in 2bbl form, I did one once,,,, ok well twice times I've done them, make sure you eat yer wheaties! But yes I agree, just going from 2 to 4 for free is worth the gasket set.
Old Oct 9, 2009 | 05:56 PM
73 fourxfour's Avatar
73 fourxfour
I would go for the free 4V upgrade. I would put my money towards a modern cam, headers and get rid of the points. I have a 73 360/4-spd. I pulled a 4v intake from the junkyard and threw on a 600 Holley. Much more enjoyable to drive around. Raised the RPM range by about 1000. But I realized when I was towing my Fairlane home, up hill from sea level to 2000 feet, that it needed more if I planned on doing that again. I had it topped out in 3rd but it would only go about 45mph in a 55 zone, and it didn't have the ***** when I put it in 4th. Towed great on more level roads. I pulled the intake from the junkyard and installed it by myself. I was 33 and in good shape. I would suggest having someone there to help whether you are a tough guy or not.
Old Oct 9, 2009 | 07:08 PM
jimbeam&coke
Thanks guys
