1993 f250 E40D which shift kit?
Old Oct 4, 2009 | 04:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
10025 - B&M Light Truck Shift Improver Kit
OR
B&M ShiftPlus Electronic Shift Improver
which is better? pro's/con's with each?
either would work with my truck right?
1993 f250 xlt reg cab 4x4 7.3 non turbo diesel with E tranny code (E40D)
thanks.
p.s.
this is a good size cooler right?
B&M SuperCooler Transmission Cooler:
# Automatic Transmission Cooler Only16,000 GVW
# 9,800 BTU
# 11'' x 5-3/4'' x 3/4''
130-70255
Old Oct 4, 2009 | 09:48 PM
FORDF250HDXLT
ok,my trigger finger for the shopping cart can't wait much longer lol.
anyone see any probs with the valve body shift kit and this cooler?
i need to flush the trans and replace the leaking pan anyway.just didn't know if the electric one-a bit cheaper,had any advantages.i guess you can turn it off and have mushy shifting when not loaded but ahh,i dunno.i figure its a truck anyway,and not 100% sure if it even works with this truck.
any opinions either way? guess i can't go wrong here....i hope lol.
Old Oct 5, 2009 | 12:16 PM
Lazy K's Avatar
Lazy K
You should post this on the pre-power stroke diesel page, may be guys there who would know.
Just from reading info here most guys seem to prefer the Transgo kits.
If you are doing a fluid change make sure you drain the torque converter.
Old Oct 5, 2009 | 06:41 PM
FORDF250HDXLT
Thank you kindly for the information.
The transgo looks good as well, I wounder what the "Has EPC boost valve" is?
Will ask them over there as well thanks.
Yes,converter will be flushed as well.Thanks for the reminder too though.
Old Oct 6, 2009 | 08:00 AM
l-m tech's Avatar
l-m tech
the kit does come with a pressure regulator boost spring and valve.this is how many shift kit function.they raise line pressure to give a firmer shift.
Encho
Mar 3, 2016 02:45 PM
Dutter 2
Dec 18, 2015 01:44 PM
luthoro
Jul 19, 2013 07:44 PM
linckeil
Sep 6, 2009 11:07 AM
