EBPV delete pedestal
Old Oct 3, 2009 | 07:51 PM
61 uni's Avatar
61 uni
Can I buy a pedestal with ebpv already removed? Looks like i'm going to be doing o-rings and I'd like to eliminate this potential leak while i'm in there.
Old Oct 3, 2009 | 07:54 PM
BigAlsPSD's Avatar
BigAlsPSD
I know they are sold probably Clay at RiffRaff, but someone will chime in soon with a link for you.
Old Oct 3, 2009 | 07:56 PM
jdecker88's Avatar
jdecker88
Clay can get you one for around a 120 Brandon hurry up and get it drop ship it and come pu to neals saturday and we'll put it on
Old Oct 3, 2009 | 08:11 PM
Bigcat350's Avatar
Bigcat350
Why not just plug yours and save $100-$120 and spend it on a performance mod? Just do this .
Tap Pedestal picture by Eddie__S - Photobucket
All you need to do is gut it and tap it and put a NPT tap plug in it.
Old Oct 3, 2009 | 08:17 PM
megawatt00's Avatar
megawatt00
That is what we did to mine at RRE. Barney and I noticed that it was leaking and at the last minute decided to delete it and thanks to Phil for running out and grabbing the plug for me.
Old Oct 3, 2009 | 08:20 PM
Bigcat350's Avatar
Bigcat350
Yea Jim I was there. It works great for a cheap fix.
Old Oct 3, 2009 | 08:35 PM
jdecker88's Avatar
jdecker88
Turbo :: Gut and Plug video by MazdaMartinb4k - Photobucket
Here ya go brandon
Old Oct 3, 2009 | 09:02 PM
Bigcat350's Avatar
Bigcat350
I would use the NPT plug its a tapered plug to make sure it seals off good.Name:  99.5 Truck 041.jpg
Old Oct 3, 2009 | 09:05 PM
61 uni's Avatar
61 uni
Originally Posted by jdecker88
That looks easy. Anyone know what size tap he used? How hard is it to remove the turbo and pedestal?
Old Oct 3, 2009 | 09:28 PM
Bigcat350's Avatar
Bigcat350
Not sure what size he used but. Most use a 1/4 NPT tap and plug see the pic above you can see the tap and to the right you can see the plug. Removing the turbo and pedestal is not hard. Just take your time read up on it before you begin there are a few tricks that makes it easier the clamp to the down pipe is a pita after you do it a couple times its easy.
Old Oct 3, 2009 | 09:32 PM
megawatt00's Avatar
megawatt00
Yes you were. You should have stayed for the party at Ricks. We called it quits at 5 am.
I can't remember if it was 1/8" or 1/4" it is really easy to remove the turbo and pedistal a few bolts, the spider the clamp off the babys butt and the dwon pipe clamp and your golden.
Old Oct 3, 2009 | 09:35 PM
Bigcat350's Avatar
Bigcat350
[quote=megawatt00;7997168]Yes you were. You should have stayed for the party at Ricks. We called it quits at 5 am.
I did for a while the wife called from the room at 1:00am so thats when I bugged out.
Old Oct 3, 2009 | 09:38 PM
Izzy351's Avatar
Izzy351
It's a 1/4" NPT tap & plug. You don't even have to drill the hole out -- it's already the right size for tapping. 1/8" NPT is for the pyro sensor adapter...
EDIT: And if you're going to use a standard 1/4" NPT pipe plug, don't run the tap all the way through like he did. Try test fitting the plug when you get about half way into the hole with the tap. If you go too far, the plug won't get tight.
Old Oct 3, 2009 | 09:44 PM
Bigcat350's Avatar
Bigcat350
Yep Sorry about that Joe is correct 1/4 NPT and Plug
Old Oct 3, 2009 | 10:08 PM
megawatt00's Avatar
megawatt00
[QUOTE=Bigcat350;7997186]
I do remember you leaving I didn't realize that it was at 1am.
