WW install
Old Oct 21, 2009 | 07:57 PM
  #46
big poppa's Avatar
big poppa
What I'm wondering is why your taking the turbo apart just to do the WW?? Are you rebuilding the turbo, was there in and out play??
Old Oct 21, 2009 | 08:04 PM
  #47
tdpower's Avatar
tdpower
re
I had to take off the inner housing to get the middle section bolts out (one was missing and one loose). I did not take the bearing and stuff apart that washer just moves around and did not pay attention to the orientation when I took it off. I was looking on Guzzle's site on the van turbo rebuild but seems to be a little different. Just don't want to burn up the turbo.
Old Oct 21, 2009 | 08:16 PM
  #48
big poppa's Avatar
big poppa
Ok Grant, wasn't sure what bolts were loose you were talking about.
Old Oct 21, 2009 | 09:39 PM
  #49
tdpower's Avatar
tdpower
After looking at it more I think I'm Ok but any feedback would be appreciated. I'm going on a long road trip next week (2800 miles).
Old Oct 21, 2009 | 09:59 PM
  #50
Izzy351's Avatar
Izzy351
The little notches go TOWARDS the oil housing. Once you know that, it only goes in one way. You have it the correct way in the pic.
Old Oct 21, 2009 | 10:16 PM
  #51
tdpower's Avatar
tdpower
Thanks Joe that was the confirmation that I was looking for .
Old Oct 21, 2009 | 11:42 PM
  #52
big poppa's Avatar
big poppa
Grant, I see you don't have any gauges, just make sure when you button everything up that you get eveything lined up and snugged down to proper specks. When you have gauges, you can see if things arn't right like high EGT's and low boost, thought I would add this. What I did, I checked all the clamps after about a hundred or so miles to retourqe if needed.
Old Oct 22, 2009 | 02:30 PM
  #53
tdpower's Avatar
tdpower
I got the wicked wheel today and put it on but very hard to turn with it on. Without the wheel on it turns freely. Any ideas what is wrong?
Old Oct 22, 2009 | 02:43 PM
  #54
tdpower's Avatar
tdpower
This isn't my pic but notice the bearing in the middle is sticking up. Turbo Removal&Rebuild 024 on Flickr - Photo Sharing!
mine is flush. I don't know what they heck is going on.
Old Oct 22, 2009 | 03:17 PM
  #55
Izzy351's Avatar
Izzy351
The bearing should be flush down in there. Not sure what you have going on there... Is it a new one or did you reuse the original??
EDIT: Here's what the bearing should look like in the backplate before you bolt it to the oil housing:
Old Oct 23, 2009 | 04:56 PM
  #56
tdpower's Avatar
tdpower
Finish up today. Had a few problems that I banged my head about for a while but was a good learning experience. Thanks for everybody's help.
Old Oct 23, 2009 | 05:21 PM
  #57
big poppa's Avatar
big poppa
Good deal Grant, put that WW in your sig..
Old Oct 23, 2009 | 06:07 PM
  #58
tdpower's Avatar
tdpower
Thanks Mike. Updated the sig. Going tomorrow on a big hill on the highway so we will see the difference. Kicked it in town hard and no surge so far.
Old Oct 23, 2009 | 06:24 PM
  #59
big poppa's Avatar
big poppa
Sounds good, you'll really notice it when or if you tow, made a big difference with mine. Lost a pound or two of boost but the trade-off was no surge, for me anyways, subscribing..
Old Oct 24, 2009 | 10:51 PM
  #60
tdpower's Avatar
tdpower
Went on a 400 mile trip today unloaded. Kicked it hard going up a 6% grade and no surge. Did not get any on the trip. Probably won't be towing for a while but still notice the difference. On the old compressor wheel definitely got surge on the same hills. Had the pleasure of blowing by a 6.0 on a hill . He was trying to pass and I did not want to get stuck by the semi's. Unfortunately, he was hauling a very small boat.
