Ol grey has sprunk a leak. A leak I can't find for the life of me. I installed a red head about 3 months ago. Fittings going into the box, dry and tight. fitting on the side of the ps pump has movement in the fitting,but the bolt is tight? Is there an o ring in this fitting like the two that go to the steering gear? Is a PS line about to go?
I was thinking of getting some new hoses,is there an aftermarket braided SS hoes set made by any one?
On the plus side I had to remove the IC pipe to get a look at the steering gear and PS pump, So I did the foil delete, AIS plus foil delete=
