Sponsored by: Auxito
engine miss code shows #4 cyl
Old Oct 1, 2009 | 06:58 AM
breston's Avatar
breston
code for #4 cylinder miss comes on. I have changed the plug and wire and it improved slightly but code reappears and engine miss is still occuring. It is getting spark according to the in line tester. Could it be the coil pack? Any suggestions would be appreciated
Old Oct 1, 2009 | 08:18 PM
torkum's Avatar
torkum
Most likely the COP was/is the problem. If you want to check it before buying a new one just switch the COP to another cylinder. The code should go to the other cylinder.
Old Oct 2, 2009 | 04:44 AM
breston's Avatar
breston
thanks I will try that
mike L
General Automotive Discussion
Jan 22, 2013 10:47 AM
dantsg
1997 - 2003 F150
Oct 31, 2008 08:36 PM
SproutW
Dec 9, 2007 05:21 AM
JerryandSue02
1997 - 2003 F150
15
Jan 13, 2006 03:49 PM
TallPaul
May 4, 2000 10:48 PM
