Sponsored by: Auxito
ABS Light
Old Sep 30, 2009 | 05:50 PM
nmarcoe's Avatar
nmarcoe
ABS Light
I put new brakes on the back of my 2001 Ford F150 a couple of weeks ago and today I put brakes on the front of the truck. I went for a ride and the ABS Light comes on when I apply the brake. Any suggestions what might be causing the light to come on when I use the brakes. The light went off when I put the brakes on the rear for a little while. I figured after I put the brakes on the front today that would solve the problem, but no such luck. The light doesn't come on every time I step on the brake. When I shut off the truck it cancels the light and at some point the light comes back on again.
Thanks,
Noah
Old Sep 30, 2009 | 07:34 PM
TidePride50's Avatar
TidePride50
My wife's 03 Explorer ABS light would periodically come on and go off and it turned out to be the speed sensor. Not sure if the 2001 F-150 even has a speed sensor, but it's a thought.
Old Sep 30, 2009 | 08:32 PM
torkum's Avatar
torkum
Check for brake dust build up on the abs sensor.
Old Sep 30, 2009 | 09:12 PM
95bigtime's Avatar
95bigtime
Have the codes pulled-probably abs sensor. There is 1 in center of rear diff and 1 each front wheels.
Old Sep 30, 2009 | 09:31 PM
steve(ill)'s Avatar
steve(ill)
if its the sensor it will come on "sometime" when you are driving. if it only comes on when you push on the brake, it might be related to that. You had the light before the brake job?
Old Oct 1, 2009 | 09:23 AM
nmarcoe's Avatar
nmarcoe
ABS Light
Thanks for responding. I didn't see the sensors on the front end yesterday, but that certainly could be the problem. The ABS Light began lighting up before I did the rear brakes and since doing the back and now the front.
Maybe I'll take a closer look for the sensors and see if they are functioning correctly.
Thanks again,
Noah
cptaylor
Feb 10, 2015 12:46 PM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
EgoMan
Nov 29, 2006 11:38 PM
goose213
1978 - 1996 Big Bronco
Nov 22, 2004 03:12 AM
rick
Jan 27, 2001 10:12 PM
