ABS and E-brake lights on
Old Nov 29, 2006 | 11:34 AM
EgoMan's Avatar
EgoMan
I backed my truck out this morning and when i put it in drive the ABS light and the parking brake light came on and stayed on. I know my brake isnt engaged at all it works great and i know the ABS system works fine too. Any idea what will cause these lights to come on? Its on a 92 F-150.
Old Nov 29, 2006 | 05:13 PM
EPNCSU2006's Avatar
EPNCSU2006
Make sure that the master cylinder is full of fluid and that the float switch wiring is properly plugged in.
Old Nov 29, 2006 | 07:49 PM
EgoMan's Avatar
EgoMan
You know I noticed the master cylinder was slightly low the other day but I forgot. Is that wiring in under the hood?
Old Nov 29, 2006 | 08:03 PM
SteelySlayer's Avatar
SteelySlayer
You know I had the same problem and noticed I had a leak. I wanted to find it so I tried to take the rear drums off. And I mean I tried and couldn't. It took a monster pry bar and both my dad and myself to get those drums off. There was no pad left on either shoe and about an 1/8" lip on the drums. I was amazed that I was still stopping fine. I fixed the problem, but I had to buy new drums and all new parts for the brakes. Hopefully you won't have the same problem I did. You shouldn't if you check them periodically. I sure learned my lesson. Oh and once I fixed the brakes, the lights went off.
Old Nov 29, 2006 | 09:18 PM
EPNCSU2006's Avatar
EPNCSU2006
The wiring attaches to the master cylinder reservoir, under the hood...
Old Nov 29, 2006 | 11:38 PM
EgoMan's Avatar
EgoMan
Well the drums and pads have about 611 miles on them and those are very easy miles with mimimal stoping so i doubt there bad...but its worth a look I just went through a little mud puddle on monday so maybe I have a bunch of mud up in the drum.
spinella
Jun 22, 2011 01:24 PM
blee1ash
Mar 8, 2011 11:55 AM
saalfelder
1983 - 2012 Ranger & B-Series
Jun 13, 2007 04:21 PM
StorminTexan
1997 - 2003 F150
43
Apr 6, 2006 10:23 PM
not2litl
Feb 25, 2004 06:41 AM
