How does this sound...
Old Sep 30, 2009 | 12:16 PM
rockher_man's Avatar
rockher_man
Question How does this sound...
...Eagle 3.25" cast steel crank
SIR 5.4" I-Beam rods
SRP forged flat tops....to start....
Then...
1.7 Comp Cams roller rockers
Canfield Heads, 1.94/1.60 valves
...maybe shave a little off if needed as to get
down to 57cc chambers...
...so to keep compression below 10.5:1 for pump gas...
Hyd. flat tappet:
.587/.587 228* duration @.050
I know.....but...I already got 2 motors in the garage...
Old Sep 30, 2009 | 10:06 PM
fordeverpower's Avatar
fordeverpower
a 331? id go 347 or stay 302, canfield has good heads, not the cheapest by any means.
The dynamic compression is more important than static, the cam size and rod has a lot to do with it, and aluminum heads will help.
I did build a 331 once but we got a good deal on it. I had to notch the bottom block bores, for the nut to have clearence.
Old Oct 1, 2009 | 08:53 AM
rockher_man
Lightbulb Cylinder notch...
...that's whats got me thinkin'...
Was it 'cause of the rods you used or just the 331" kit overall?
I was hopin' that maybe goin' to an H-beam rod "might" get me
around that...
By the way...have not been able to pull up the Canfield website
for a couple days now and the phone just keeps ringing...
Old Oct 1, 2009 | 12:58 PM
fordeverpower
I like rhs heads they offer good value and flow. The nut on the rod bolt so so damn close to the bottom of the bore, so i clearance it slightly not a big deal. A capscrew bolt would most likey be fine.
Old Oct 2, 2009 | 09:42 AM
rockher_man
Thumbs up RodZ...
...Kool...that is what I was thinkin'...thanks...
Which 331 "kit" did you use?
The only reason I was likin' this setup is 'cause I spoke with a
dude that has done this & it's been on the street for about
5-6 years and still haulin' a$$...in a vintage truck...
With occasional 1320-passes...
Old Oct 2, 2009 | 08:27 PM
Mustang6147's Avatar
Mustang6147
Why put 194/160 heads on a car after market??? Go 202/160 If you are trying to get near 500 hp you might consider 205/165. But 194's are a waste in my opinion, I cant beleive they make them after market.
Old Oct 3, 2009 | 09:52 AM
385seriesHemi's Avatar
385seriesHemi
If you use the 1.94s for a mild street app with a .587 lift you should flow pretty well with those heads. If you go too large the air velocity you want won't be there for fuel suspension. Make sure your seats and valves will be cut accordingly for optimum flow.
Thats a good reason, its dependable!
Old Oct 3, 2009 | 11:11 AM
fordeverpower
1.94 valves in an optimized port are fine. I have found that stock ford heads usually like bigger valves, but 2.20/1.60in sbf literally touch. The seats leave a super sharp ridge where they meat and is a great place for cracks to start. Nascar pulls 400 cfm with a 2.15 valve by the way.
Old Oct 6, 2009 | 08:27 AM
rockher_man
Thumbs up Great info...
...thanks...
I know that Canfield's owner has reciently decided to go into retirement
but...I ran across THIS earlier this morning while researching cylinder heads......
HOT ROD WHEEL COMPANY / CANFIELD CYLINDER HEADS - Myron Bowling Auctioneers
Good for him...obvisously he has enjoyed a very successful career...bad
news for me...I DO know that the Canfield Part #20-450-58-1 is very
similar to being and basically an AFR165 equivalent...
FWIW...
Old Oct 8, 2009 | 08:18 AM
8bahead's Avatar
8bahead
Thats true John Fenton owner of canfeild has closed its doors, John has retired.
Be careful buying older canfeilds as they were prone to cracking and some other issues.
Trick flow 190 fast as cast heads, would be a good choice can be used for small blocks with room to grow to 351 engines, cam accordingly to your application.
With either rod you choose you'll still have to notch the block accordingly.
Old Oct 8, 2009 | 09:12 AM
rockher_man
Thumbs up Kool...
...good to know...thanks for the "heads" up...
Old Nov 25, 2009 | 08:00 AM
rockher_man
Question Probe Industries...
....has ANYONE EVER either of these Probe pistons???
12347 - Ford 331/347 -4.0cc Flat Top SRS Pistons
These are Probe 's forged SRS-Series pistons...
2618-t61 Forged Aluminum
I hi-lited some of the minor differences...
A) Probe #10666-030 - 4.030"
Compression Height (in) 1.175
Wrist Pin Diameter (in) 0.912
Deck Thickness (in) 0.275
Top Ring Groove Size 1/16 in.
Second Ring Groove Size 1/16 in.
Oil Ring Groove Size 3/16 in.
Top Ring Land (in) 0.220
Second Ring Land (in) 0.140
Bottom Ring Land (in) 0.075
Compression w/ 58cc Chambers = 10.37
B) Probe #12347-030 - 4.030"
Wrist Pin Diameter (in) 0.927
Oil Ring Groove Size 3.0 mm
Top Ring Land (in) 0.230
Bottom Ring Land (in) 0.070
I could use "some" help......please???
I was thinkin' last night...the last time MY 2 mits assembled a SBF...
there...THERE WERE NO ROLLERS!!!!!!!!
...I had to look that one up in my archives...
Old Jan 25, 2010 | 12:40 PM
ford_0004's Avatar
ford_0004
What is tq/hp that is expected to come out of a 331 stroker I've been throwing this idea around for 78 f150 4x4 ?
Turbolark
2004 - 2008 F150
15
Aug 2, 2016 10:06 PM
trevorrules
Jun 7, 2016 09:07 PM
48prerunner
13
Oct 24, 2015 10:52 AM
tcjhkbjt
May 16, 2015 09:53 PM
wtmjr43
2004 - 2008 F150
Apr 25, 2015 04:10 PM
