1992 ford engine question
Old Jan 28, 2010 | 02:49 PM
kirbykoon's Avatar
kirbykoon
Question 1992 ford engine question
I just recently replaced my torque converter after the truck sat about a month. .When i got it done, i have oil pressure(engine) problem. the truck starts fine and the oil pressure looks good at startup, but after a few seconds, it will go to no pressure and the engine starts to rattle for a few seconds and pressure comes back and rattle is gone,it does this continually, the pressure builds and than goes to zero, what I would like to know is when I rotated the engine backwards when i took out the torque converter bolts, could i have messed the oilpump up? the oil needs to be changed, cause it is pretty gunky, or could the pump go out without warning?
Old Jan 28, 2010 | 04:03 PM
lew52's Avatar
lew52
What motor is in the truck ?? Sounds like it might have a clogged oil pickup tube & screen , its a very comen problem ....Lew
Old Jan 28, 2010 | 05:44 PM
kirbykoon's Avatar
kirbykoon
its a 351(5.8)
Old Jan 28, 2010 | 05:49 PM
lew52's Avatar
lew52
You can look inside the valve cover & see what it looks like , if theres alot of sludg in there then its worse in the pan ..Lew
mtbnski
Nov 10, 2014 08:16 PM
Dr. Dirt
1997 - 2003 F150
Jun 29, 2014 09:40 PM
metriccar
Mar 18, 2013 12:59 PM
hivoltj
Apr 13, 2011 02:49 PM
Franken-Truck
20
Sep 13, 2004 02:32 PM
