Engine isn't getting power
Old Sep 30, 2009 | 10:29 AM
Ag2009's Avatar
Ag2009
I have a 95 F-150 5.0. My truck was fine until out of the blue the engine started sputtering and knocking. When I try to give it gas, the engine doesn't rev up or anything, it just gives off a random knock. If I give a little bit of gas, it will hesistantly go up to about 20 mph. I was told it might be the ICM but I got it tested and it came out good. Whenever it wants to shut off on me I turn off the truck and start it back up with no problem and I can run it again slowly and hesitantly. There's no problem when its idling and it starts up just fine. Can anybody help me out?
Old Sep 30, 2009 | 12:00 PM
94MustangGT's Avatar
94MustangGT
Any codes? Also, hows the fuel filter? I would change it and check the pressure if the problem persists, granted there are no codes to address.
Old Sep 30, 2009 | 12:01 PM
subford's Avatar
subford
Check your fuel pressure with a gauge.
If that is OK check for slop in the timing chain.
If that is OK it might be the PIP sensor or the computer.
You need to pull the codes first so you (and I) are not guessing so much.
Old Sep 30, 2009 | 03:31 PM
Ag2009's Avatar
Ag2009
I'll go get those codes and check those things out. Thanks for the help so far.
Old Sep 30, 2009 | 04:31 PM
subford's Avatar
subford
You can read them yourself, just go to this link if you do not know how:
Ford Fuel Injection How To Run a Self-Test
Old Sep 30, 2009 | 05:35 PM
Ag2009's Avatar
Ag2009
Thanks.....I'm kind of a newbie at this but as soon as I get the chance I'll post the codes.
Old Sep 30, 2009 | 07:52 PM
94MustangGT
^ I have a $30 Ford OBD I scanner, that displays the actual code number. No counting flashes. It comes with a nice manual to explain the codes too. I highly recommend it. Check your local auto parts store, if interested.
Old Sep 30, 2009 | 08:33 PM
subford's Avatar
subford
Yes that scanner works well.
Here is a photo of it:
Old Oct 1, 2009 | 08:32 AM
camo1987f150's Avatar
camo1987f150
Does your truck have dual fuel tanks?
Old Oct 1, 2009 | 12:24 PM
BCHauler's Avatar
BCHauler
I owned that scanner and used it all the time. Quick and easy to use. It was the only thing stolen from my truck when I forgot to lock it once last spring.
Old Oct 1, 2009 | 09:35 PM
Ag2009's Avatar
Ag2009
yea it is dual tanks
Old Oct 1, 2009 | 09:43 PM
camo1987f150
I have an 87 f150 with the dual tanks and i had the same problem but it was only with one tank. Check and see if both tanks fuel pumps are working properly by checking the pressure on the pressure check which should be between the fuel filter and regulater. Also have you changed the fuel filter?
Old Oct 1, 2009 | 10:08 PM
Ag2009's Avatar
Ag2009
I changed the fuel filter and it ran somewhat better for a few minutes and then it went bad again... I checked the codes, and assuming I got them right, I got 11-11.
Old Oct 1, 2009 | 11:33 PM
kc0rey's Avatar
kc0rey
11 means "System Pass". Check that fuel pressure and timing.
Old Oct 2, 2009 | 12:13 PM
camo1987f150
also you made need to replace the fuel lines
alloro
Mar 10, 2017 02:51 AM
abumchuck
Modular V10 (6.8l)
Aug 29, 2013 08:24 PM
79Bronk
May 31, 2011 03:53 PM
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
Nathan
Aug 20, 1999 10:47 AM
