Sponsored by: Real Truck
Replacing front shocks - top bolt
Old Sep 29, 2009 | 09:09 AM
Greenlawnracing's Avatar
Greenlawnracing
Is there a trick to getting it off? It took me forever to get one off last night using a 19mm wrench. Very tight fit, and the threads are really long. I didn't see any way to get a deep well socket and a ratchet in there due to the inner fender. Am I missing something?
I was going to try a ratcheting wrench tonight on the other side.
Not sure if it makes any difference, but my truck is 2WD.
Old Sep 29, 2009 | 12:52 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Spray it with PB-BLASTER, and let it set a while. That is some good stuff.
Old Sep 29, 2009 | 02:07 PM
Greenlawnracing
its not that its too tight, the issue is fitting a socket in there.
Old Sep 29, 2009 | 03:39 PM
Workin4ALivin's Avatar
Workin4ALivin
I just did mine. Its a 4wd, but has coil springs. I just used a wrench to break it free then used my fingers.
Old Sep 29, 2009 | 04:51 PM
LMS Residential's Avatar
LMS Residential
Carefully cut the exposed top threads off with a sawzall, it then allows you to get a standard socket/wrench over the top without having to use a deep well socket.
Old Sep 29, 2009 | 08:18 PM
akford351's Avatar
akford351
I use a ratcheting wrench whenever I do them... these studs are a PITA.
Old Sep 29, 2009 | 08:29 PM
Eng1Driver's Avatar
Eng1Driver
I used a Sawzall and cut the whole bolt and stud off. The problem you run into using a socket is you end up spinning the whole rod in the shock and never loosen the bolt any.
Gumshoebelly
Aerostar
25
Oct 5, 2018 12:36 PM
eallanboggs
Apr 17, 2008 09:17 AM
eco
Garage & Workshop
Jun 18, 2007 02:37 PM
Hangfire
Garage & Workshop
23
Dec 17, 2005 04:17 PM
Curtis'70
29
Sep 19, 2004 03:47 PM
