My eyes can't focus... they keep bobbing up and down
that's an O2 sensor.... generic code for low flow. Probably a Catalytic converter sensor, maybe plugged? Try disconnecting and re-connecting the wire... if it's there. May be time for a new CAT.
So what does it cost to replace the "Catalytic monitor sensor" specifically Bank 2? Not even thinking about replacing the CAT.
Anyone here have a CAT for sale?
No such thing on a 6.0. Only emissions you have is egr valve and catalytic converter. Might consider the ebp sensor as emissions ( using the term loosely)
The code I got was P0430 - Catalyst System Efficiency Below Threshold. Bank 2.
