clothes dryer problem
Old Sep 27, 2009 | 08:30 PM
jake00's Avatar
jake00
I've got a basic maytag front load clothes dryer that has developed a problem.
One of the 3 "paddles" on the barrel came loose. its held on by 3 screws, two are gone and the 3rd is pretty loose.
is there any sort of easy access to this barrel part, if i could access it i could just rescrew the thing on.
Ideas?
Old Sep 27, 2009 | 08:57 PM
weadjust's Avatar
weadjust
The top should pop off to access the drum. The top on most dryers is held on with some clips that expand into holes in the top.
http://www.ehow.com/how_4841963_chan...tag-dryer.html
Carefully and slowly slide the blade of a flat-head screwdriver under the top panel of the dryer, starting at one of the front corners. Very carefully tilt the screwdriver to pry the top panel upward, taking care not to scratch the finish. Move the screwdriver around the top panel as you pry it up a little at a time. You should hear two pops, one at each corner. These are the retaining clips coming loose. After both clips have popped loose, you should be able to lift up the top panel like the hood of a car.
Old Sep 28, 2009 | 06:51 AM
projectSHO89's Avatar
projectSHO89
Use a metal putty knife of the screwdriver is unable to get to the spring-clips.
Old Sep 29, 2009 | 10:44 AM
shorebird's Avatar
shorebird
Here is the Maytag manual source site; Maytag Manuals and Literature Search
Old Sep 29, 2009 | 06:26 PM
jake00's Avatar
jake00
kickass, Thanks
Old Sep 29, 2009 | 06:30 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
FTE rocks! These dudes are phenominal.
Tim
Old Sep 30, 2009 | 09:08 AM
billy12360's Avatar
billy12360
you will probablly have to remove screws from the back, and from the lint trap thing...
mark a.
13
Jul 9, 2011 09:00 AM
websthes
Nov 8, 2007 09:20 PM
john112deere
Mar 13, 2006 11:18 PM
jskufan
May 16, 2004 07:07 AM
BuiltToughF250
26
Dec 27, 2003 12:41 PM
