2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Fuel filter replacement- I broke the retaining clips
Old 09-13-2009, 08:08 PM
Blowinsmoke's Avatar
Blowinsmoke
Blowinsmoke is offline
I just changed the filter on my 07 expedition. I tried to be careful when lifting the both the blue pin and red pin on the double line side of the filter. As you probably know, the filter sits sideways making access to the retaining clips very difficult. I did manage to remove all the clips but broke the both in the process. I put them back in upon reinstallation of the new filter. One side of the clips are missing. Do I need to get new ones or do you think they will remain in place.,
Also on the outlet side. the metal clip was not quite in place on my first try. Fuel sprayed out as I started the vehicle up. I re-engaged the primary clamp with the special tool to reseat the line. The metal bracket or (clamp) had to be reseated to stop the leak.
Old 09-26-2009, 12:18 PM
Blowinsmoke
I stopped by the Dealership today on an unrelated matter. I spoke with a mechanic that I deal with. Told him about the clips breaking (red and blue). He said this happens all the time, especially when non-dealer facilities such as quickly lube places. The trucks end up in the shop by tow trucks. The fuel lines come off and needs to be completely replaced. You cant just buy the flimsly clips.
Since the clips operate in conjuction with other plastic keepers, I was thinking of just using tie wraps or other devices to keep the secondary clip from disengaging which may allow the fuel line to come off.
Any advice?
Thanks,
Old 09-26-2009, 12:36 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
I can say to my knowledge, the new style was put inplace because it is completely rebuild able. Infact most shops have the new ends. NAPA carries them also. I dont know what that mechanic is talking about, replaceing the whole line. I would buy a new end, and install it.
Old 09-26-2009, 01:02 PM
Mustang6147
Here is a photo pf the clips I am talking about, so we are on the same page, and not talking about 2 different ends. This photo is of the new rebuildable ends...
The following users liked this post:
Old 09-27-2009, 04:52 PM
Blowinsmoke
That looks like it. I will go to NAPA tommorow and get the fitting. How does the fitting come off? I ask because I don't want to damage it more. Once I have the fitting off the filter, does it simply slip off the line or is there a method to it?
Thanks for your response.
Old 09-27-2009, 05:18 PM
Blowinsmoke
Would this work. It looks like the clips that I broke.
http://www.midwayautosupply.com/pm-4...e-800-015.aspx
Russman206
1999 to 2016 Super Duty
07-07-2017 04:03 PM
ArcadeDoctor
2004 - 2008 F150
10-26-2015 11:58 AM
goblerblaster
09-01-2015 08:31 AM
ML190
08-26-2012 11:27 AM
wraysp
06-12-2010 05:30 PM
Quick Reply: Fuel filter replacement- I broke the retaining clips
