Need pointers for first pull
Old Oct 2, 2009 | 04:36 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I have been learning about this and you dont want to strap the front left, only for drag racing you strap the front down to help with the launch. You want the front saggy and soft and alot of droop, if you jack the front of the truck up by the frame, the more droop you have after ride height the better. I've learned hanging weight is better than strapping the front down. But you've already hung weight all over the rest of the truck
Old Oct 2, 2009 | 05:09 PM
stroken's Avatar
stroken
I knew you were supossed to hang weights on the front left. I figured since i dont have the bracket to hang weughts strapping the front down would help with the problem.
Old Oct 2, 2009 | 05:13 PM
PowerstrokeJunkie
from what ive read, strapping the axle to the frame, engine will still lift the frame up and just pull that tire off the ground
Old Oct 2, 2009 | 05:55 PM
rebelchevy02's Avatar
rebelchevy02
I would run about 20-30 psi in the front, and somewere around 50-60 in the rear. (depends on the tires) Just be sure you have a means to pump your tires back up, PITA driving around with that little air in the front. (less then 30 anyways, been there after yanking a dodge around)
Zejokee
May 19, 2014 12:44 AM
majestek12
Dec 11, 2013 11:24 AM
countrycar
Nov 21, 2012 07:16 PM
rideracelivemx7
20
Jul 22, 2011 11:24 AM
ron's power stroke
25
Oct 26, 2008 08:43 PM
