Help cold air intake help !!!!
Old Sep 24, 2009 | 08:01 PM
turbodiesel123's Avatar
turbodiesel123
i have a 1994 ford f250 xlt 7.3l turbo diesel vin. k, i cant find a cold air intake system anywhere if anyone has found one or knows where to get one, pleae tell me i want one desperately thanks
Old Sep 24, 2009 | 09:12 PM
johnboggs21's Avatar
johnboggs21
No one makes a cold air intake for our trucks. If you want one youll have to make it yourself. Its been on my to do list for a while.
Old Sep 24, 2009 | 09:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
turbodiesel123,
Welcome to FTE and the IDI diesel forum.
Hypermax still sells a cowl induction kit.
Other than that, make your own.
Old Sep 24, 2009 | 09:38 PM
bad12jr's Avatar
bad12jr
Hey dave, does the cowl induction piece go between the radiator?
Old Sep 25, 2009 | 01:40 AM
Sycostang67's Avatar
Sycostang67
The hypermax kit involves cutting a hole in your firewall near the brake booster so it pulls cool air in from the cowl panel. One guy mentioned the kit dropped his EGT's by 300*. The kit isn't too expensive so I plan to try it out. If you go back a few pages, there was a thread about a member who installed one on his truck. He posted some pics so you can see it installed if you like.
Old Sep 25, 2009 | 12:07 PM
axe_handle's Avatar
axe_handle
The Hypermax Cowl Induction thread is here:
https://www.ford-trucks.com/forums/8...induction.html
The factory K motor induction was a cold air intake right over the driver side battery. I don't think it flows as well as the Hypermax piece, but it does have ram air fuctionality, even if it is a particularly good implementation of ram air.
Ultimately I want to run the factory cold air AND the Hypermax cowl induction, but I need to make a 4" 2 into 1 fitting to make that work.
Old Sep 25, 2009 | 08:40 PM
Dave Sponaugle
Look at that small intake and think about moving 846 cubic feet of air through it every minute.
At 14 pounds of boost at 3300 RPM that is what you need to get through that little opening.
I wish I had the measurements of the opening, I know it is small and I am going to guess 1" x 8".
If 1" x 8" is correct, to get 846 cubic feet of air through the opening, the air velocity would have to be at least 86.7 MPH.
So if you are trying to pull a load up a hill in second gear at 3300 RPM, that intake is a big restriction since your speed is well under 87 MPH.
4" x 10" intake, 5 times the size.
So at any speed over 32 MPH, I have ram air at 3300 RPM and 15 PSI boost.
paintubturner
Dec 5, 2016 11:22 PM
brkncly
6.4L Power Stroke Diesel
Apr 15, 2015 07:53 PM
Nseal1996
Aug 2, 2014 08:33 PM
trucker01
16
May 10, 2014 09:23 PM
Canadianpowerstroke
Dec 8, 2013 05:25 PM
