I just replaced my flexplate and reinstalled my tranny. The overdrive cancel switch will not work. I believe the overdrive is working, just can't kick it out. I checked the fuse and replaced the button. All wires checked to the tranny. Anyone know which set of wires to the tranny contain the overdive? I am going to check them from point to point, but would like to narrow the search.
You can check the wires on the trans all you want and you won't fix this problem. The OD switch and light are not connected to the transmission. They connect to the PCM. The PCM then decides when the shift the transmission.
Most likely the wires are broken where the steering column tilts, which is right where the wires exit the end of the shifter. Take the plastic cover off the steering column and you can get to it.
I will check that this weekend. When I swapped my flexplate, I noticed the wires in the main plug on the tranny's right side had the bare wires showing. Looked like someone had pulled on the wires instead of the plug. I seperated them and then sealed them with silicone to protect them from the weather. Could have one of them broken at the plug.
It si possible the wires were pulled out but I must aggree about the wire in the shifter. They are very small and break easy after time and usage.
I would agree with the shifter wires but since ggirten just had the tranny out, I have to believe the problem lies in the plugs/wires/connections at the tranny. Sorry ggirten, I can't tell you which plug comes from the pcm.
The wiring harness your looking for is on the right rear near the tail shaft, it goes into the main plug for the shift solenoids and such. the overdrive switch goes into the PCM then the PCM tells the trans what to do. The wires to the PCM from the switch are Tan/white and white/light green.
I've got a similiar problem that seems to be more intermittent. If it's in Park, the OD lite turns on and off. But once I put it in D the OD lite stays off although every once in awhile it might work in D.
So I removed the 3 screws on the steering column housing but it looks like the igition switch is in the way. Is it just the 3 screws that need to be removed?
Oh yea, it's a 2001 F250.
Opened my column up this past weekend. Everything looks good there. I guess the next step is to remove the suspect plug from the tranny and go through the wiring there. I suppose if this needs to be replaced, it is a dealer item and the whole harness would have to be replaced..
Were you able to establish that the pushbutton is actually sending a signal with a multimeter?
BTW, I checked the plug at the end of the shifter for the OD cancel switch. According to the manual, it seems to be gettiing power in the right places.
