Accessory Pulleys Not Lining Up
Old Nov 20, 2011 | 11:40 PM
bruno2's Avatar
bruno2
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="648"><!-- / icon and title --><!-- message -->I just got all of my accessories mounted up on my 1987 Bronco.It has the 351W with the V belts. The belt for the alt is not lining up with the groove its supposed to be in. I am wondering if using the after market balancer is throwing this stuff off? Do some companies offer spacers to line this stuff back up or do I need to find a different balancer drive pulley?
<!-- / message -->
Old Nov 20, 2011 | 11:45 PM
bruno2's Avatar
bruno2
Looking at the problem, I think it is just the alt that is not in its home. I did the 3G upgrade while the truck was apart. I used an alt off of a 94 Sable. It is the big case with the 8-1/4" spacing. The pulley is off by about 2" from being where it needs to be. Has anyone heard of this? Does anyone know of a fix?
Old Nov 21, 2011 | 01:15 AM
Plain Jane's Avatar
Plain Jane
I don't have a fix but you can double check if you have the right alternator by going to the web site of a parts store and typing in the make, model and year of the car you took the alternator off and then typing in the m, m, & y of the engine you want to apply it to. If they give you the same stock number on the replacement part for both then it should be compatible. good luck.
Old Nov 21, 2011 | 03:47 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Does your Bronco alternator mount in a smog pump bracket similar to this one from my 460?
(2G shown, from before my "upgrade")
http://www.flickr.com/photos/24183730@N03/2341337652/http://www.flickr.com/photos/24183730@N03/2341337652/ by http://www.flickr.com/people/24183730@N03/, on Flickr
Old Nov 21, 2011 | 05:03 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Please post a picture of the 3g mounted to the bracket, has to be something with the bracket.
Old Nov 21, 2011 | 08:57 AM
bruno2's Avatar
bruno2
It has the smog pump bracket. The bracket itself holds the alt out from the motor a couple of inches.
This is Gary Lewis's pic, but , mine is identical:
Old Nov 21, 2011 | 09:58 AM
Archion's Avatar
Archion
We need to see yours, gary's doesnt have an issue...
Old Nov 21, 2011 | 11:22 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't know if it's possible, but could you have installed the bracket or pulley 'inside out'?
You say you have an aftermarket damper.
Is there a difference in offset there?
Old Nov 21, 2011 | 02:26 PM
bruno2's Avatar
bruno2
Ok, so this what I have observed. The balancer pulley is not sticking out far enough. The A/C bracket and and tensioner pulley is out past the balancer pulley. So the balancer is at fault here. So back to the original question"is there a spacer made for these to shim them out far enough?".
Old Nov 21, 2011 | 03:20 PM
bruno2's Avatar
bruno2
Here is the solution:
http://www.professional-products.com...cessories.html
They do make spacers and apparently they are required on just about all SBF applications
Old Nov 21, 2011 | 05:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I see a .950 spacer.
You say that your alternator is off a couple of inches.
How did you get the rest of your belts to line up?
Old Nov 21, 2011 | 09:17 PM
bruno2's Avatar
bruno2
I was looking at the wrong rung on the balancer pulley to line the alt up with. I thought it went on the smaller rear rung b/c the WP pulley was sitting right on top of the second rung where the alt really goes and there was no way a belt could have went on that one w/o routing like the PS belt does.
Then I noticed that the A/C pulleys were out past the entire balancer pulley. So then that put it into perspective. My IT guy didnt post the pics I needed him to or this would be easier to explain if you could have seen what I saw. Actually the spacer is the .875 one. I held a straight edge against the face of the tensioner pulley for the A/C and let it run down to where it was in front of the balancer pulley. Then I used the inside measuring feature of my calipers to measure the gap between the face of the tensioner and the face of the damper pulley. That measurement was 0.875:". So I went to ebay (which had the best pricing) and ordered one. Should be here Wednesday.
Old Nov 22, 2011 | 10:09 PM
bruno2's Avatar
bruno2
I wish I could Archion , but , in my posting rules it says I am not allowed to post attachments.
Old Nov 23, 2011 | 04:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you feel you get something worth $25 out of this forum perhaps you should consider becoming a supporter Bruno.
I'm not shilling for FTE, It's worth that much for me just to get rid of the pesky ad's that limit the column width of the text.
In addition you get 1000 PM inbox, 1000 photos in your gallery, the ability to post unlimited attachment & files, a photo or gif in your Sig, and access to The Club,
...if you like to wade into the shark pool that is Politics and Religion.
https://www.ford-trucks.com/forums/payments.php
crazy96863
37
Dec 20, 2015 07:07 PM
luconn3
Apr 6, 2013 12:59 PM
51phil
Aug 18, 2010 01:57 PM
Handegard
Mar 23, 2009 11:57 PM
mchild
Nov 10, 2002 07:44 PM
