so beyond needing help
Old Sep 23, 2009 | 01:13 PM
Hussler's Avatar
Hussler
Originally Posted by MustangMatt96GT
fuse 15 is under the hood right and then fuse 7 is in the truck.
Well at least thats what I think, i would check both fuse boxes
Correct, that is what the diagram indicates.
Old Sep 23, 2009 | 01:18 PM
gt8684's Avatar
gt8684
Originally Posted by Hussler
Here is how the wiring goes ...
Fuse 15 50A -> Ignition switch(run) -> Fuse F7 15A -> Blinker -> Multi Switch -> Lights
ok but if the 50a fuse was blown the truck wouldent start right?
Old Sep 23, 2009 | 02:29 PM
jeep1947's Avatar
jeep1947
With a tilt wheel the wire for the turn signal will sometime pull out of the Multifunction Switch on column. Turn signal wipers and dimmer switch. Drop trim panel off bottom of steering wheel 4 screws pull MFS 2 torx screws, look at back of switch see if any wires are pulled out. On daughters ranger it is a light blue wire. Push it back in after u tighten the female part of connector. Thats how I fixed hers. Hope this helps.
Old Sep 23, 2009 | 03:09 PM
gt8684's Avatar
gt8684
ok here is the next question.... what color is the wire that leads to the truns signal fuse on the fusebox? i just jumped the fuse by using another always hot fuse, and the turn signals magically worked... i could leave it like that, but its rigged, and id rather it done right, any thoughts?
Old Sep 23, 2009 | 03:55 PM
Hussler's Avatar
Hussler
From the fuse F7 to blinker module it is ORG/YEL.
The other side of the fuse that goes to the ignition switch (run) is GRY/YEL.
Is that what you needed?
Old Sep 23, 2009 | 04:24 PM
Cuda_jim's Avatar
Cuda_jim
The truck will run with that fuse blown.
It protects fuses under the dash:
1 AC/Heater
5 not used
7 turn lamps
Does you AC/heater work? if yes, the 50a fuse is not blown.
Old Sep 23, 2009 | 04:40 PM
gt8684's Avatar
gt8684
well i checked the 50a fuse, and it was good.... ac works... i jumped the abs fuse to the turn signal fuse, and now the turn signals work!... lol
Old Sep 23, 2009 | 04:58 PM
Action4478's Avatar
Action4478
The reason I asked about the tilt , is , a wire (copper part) can be broken in side the insulation & not be visible . I have seen it many ,many times . you have to pull on the wire looking for a soft spot..
I have replaced a couple MFS's that weren't the problem...
Old Sep 23, 2009 | 05:15 PM
gt8684's Avatar
gt8684
yea... it must be a wire...somewhere...
Old Sep 23, 2009 | 05:57 PM
Hussler's Avatar
Hussler
Your key ignition (run) position is working OK as it runs other things that are working. Trace that GRY/YEL wire from the fuse back and it shows it goes to a junction near that fuse panel and connects to other wires that control things such as AC-Heater Control Assembly. Easy for me to say ...
Old Sep 23, 2009 | 06:13 PM
gt8684's Avatar
gt8684
yea no kidding.. lol... its raining, so ill have to wait till friday to work on it
Old Sep 23, 2009 | 06:25 PM
Hussler's Avatar
Hussler
Did this just happen or what? Years ago I drilled a hole in the firewall to install something and killed the back lights night lights. I did not have a clue for months until a cop pulled me over. Darn, that was hard getting up under there trying to repair the wires.
Anyway another option is to jumper the hot side of fuse #1 to the hot side of fuse #7. They both would be the same color code .. GRY/YEL .. and they both go back to the same junction. Fuse #1 controls your AC/Heater.
Just a thought
Old Sep 24, 2009 | 10:43 AM
  #28
bearhugger's Avatar
bearhugger
flasher
on my 95 turn signals are in front and hazard in back, i would change out both,very cheap
Jim
eog037
General Automotive Discussion
Nov 26, 2016 07:24 PM
forddriver78
Aug 26, 2015 08:03 PM
Duke78
Jan 17, 2010 04:58 AM
deficientblair
2004 - 2008 F150
Dec 19, 2009 01:07 AM
thedoctor
May 13, 2009 06:04 PM
