so beyond needing help
Old Sep 23, 2009 | 11:16 AM
gt8684's Avatar
gt8684
ok some of you may remember a week ago i posted about how my turn signals werent working... but my brake, and hazard lights were.... well i checked and changed the 15amp fuse, and changed the turn signal switch, still nothing... :S any ideas? i cant put it on the road till this is fixed... could the horn and cruis controlls in the steering wheel not being hooked up cause this? anything else? im totally lost on this one
Old Sep 23, 2009 | 11:33 AM
farmert's Avatar
farmert
Check the flasher relay in the underdash fuse box. Its' the roud thing in the upper left corner.
Old Sep 23, 2009 | 11:39 AM
Action4478's Avatar
Action4478
Does it have a tilt wheel?...
Old Sep 23, 2009 | 11:43 AM
gt8684's Avatar
gt8684
yes it does have a tilt wheel.... ive already changed the flasher unit...
Old Sep 23, 2009 | 11:58 AM
Hussler's Avatar
Hussler
Just checked the diagram again ...
1. Key must be in run position for flashers to work.
2. Have you checked that 15A fuse for voltage on one side, with key in run position?
Old Sep 23, 2009 | 12:06 PM
gt8684's Avatar
gt8684
well the key was in the run position, with nothing, im going to check it with a test light now.
UPDATE... neither side of the fuse on the box side is getting power.... so now power there, no flashing...
Old Sep 23, 2009 | 12:25 PM
gt8684's Avatar
gt8684
here is my fusebox...
now, in this second picture, you can see where the flasher is supposed to be, well the two wires there red with white stripe, and white with red stripe. those both have power....
Old Sep 23, 2009 | 12:32 PM
Hussler's Avatar
Hussler
That is your hazard flasher, not your blinker flasher.
Old Sep 23, 2009 | 12:37 PM
gt8684's Avatar
gt8684
wait, but i thought that the flasher in the front of the fuse box was for the turn signals?
or are you saying that the two hot wires are for the emergency flashers?
Old Sep 23, 2009 | 12:46 PM
Hussler's Avatar
Hussler
On my diagram Red/White and White/Red are for the flashers.
On my diagram Org/Yel and LtBlu are for the blinkers.
On my 97 the blinker is indeed located in front.
Are you sure you were on Fuse #7 15A and not on another as it should have power with key in the run position.
Old Sep 23, 2009 | 12:49 PM
MustangMatt96GT's Avatar
MustangMatt96GT
on my truck, there is a flasher on the back side under the dash for something... Might be blinkers back there... I always thought it was odd that they would put it on the back like that, but its to save room im sure... Check that one too.
Old Sep 23, 2009 | 12:52 PM
gt8684's Avatar
gt8684
well with the key on i just checked, the number 7 fuse, with the key on, neither side had power to the fuse... :S
Old Sep 23, 2009 | 12:56 PM
MustangMatt96GT
I would still check the flasher on the back with your head under the dash... it may not be letting voltage going through the flasher, so the fuse does not have any voltage...
Old Sep 23, 2009 | 12:58 PM
Hussler's Avatar
Hussler
Here is how the wiring goes ...
Fuse 15 50A -> Ignition switch(run) -> Fuse F7 15A -> Blinker -> Multi Switch -> Lights
Old Sep 23, 2009 | 01:02 PM
MustangMatt96GT
fuse 15 is under the hood right and then fuse 7 is in the truck.
Well at least thats what I think, i would check both fuse boxes
