E350 center drag link - how to remove?
Old May 27, 2013 | 06:04 PM
rebar13's Avatar
rebar13
I'v removed both cotter pins and nuts, but I can barely even swing a hammer up in there and I'm not sure I should be with the steering box absorbing alot of the shock.
All I want to do is replace the center link but it looks like I might have to remove the tie rod ends (fun but at least the steering box is farther away) and pitman arm from the box (rent a puller) just to get the entire assembly in a vise to wrestle the inner ball joint tapered ends from the tapered holes.
Any suggestions on pullers or tricks to separate the pitman arm from the center drag link and the left link from the center link? Not sure I want to use forks since they will destroy the rubber boot unless I can replace. Iv had it all soaking in PB for a week now, but without the nuts loose. Can I reinstall the nuts and leave them 1/4 turn loose with the cotter pin keeping them and hope it loosens with a drive around town like the wheel lug nut rim removal trick?
Thanks
Old May 27, 2013 | 07:28 PM
Tom's Avatar
Tom
Can you post a better picture of what you're trying to do? Whatever you do, DON'T use a hammer in such a fashion that the steering gear absorbs the impact.
Old May 27, 2013 | 07:50 PM
rebar13's Avatar
rebar13
Iv removed the cotter pins and nuts in the picture. How do I separate the components? I don't see how I could show or ask any clearer.
The brown bar in the fore ground is the center steering link (which actually is the right tie rod and connects to the BJ and pitman.) The oily bar behind is the left steering link (cant find that part on rockauto)
Old May 27, 2013 | 07:53 PM
Tom's Avatar
Tom
That pic is showing up as less than 2" wide, and it's hard to make out.
From what you describe a pickle fork may be your best option, but you'll trash the boots with that. If you're not replacing the joints you may need to find a way to get a puller in there. I use
THIS ONE THIS ONE
Old May 27, 2013 | 08:18 PM
rebar13's Avatar
rebar13
Oh, sorry.. I'm not sure why the same photobucket link I use everywhere doesn't work here.
Iv heard advanced auto loans out specialty tools. Maybe they have the one I need because I don't need the pitman puller yet. But I wonder if that approach (pitman and tie rod ends) would have been better and pull it all out. Then separate.
Old May 28, 2013 | 10:49 AM
PStruwing's Avatar
PStruwing
Hey rebar, I just did mine and used a pickle fork.
I bought a nice kit that allows the fork to be attached to an air hammer or be hit with a Hammer. Took a bit but it popped out.
https://www.ford-trucks.com/forums/1...-tie-rods.html
Old May 28, 2013 | 01:56 PM
rebar13's Avatar
rebar13
Yup.. That's the center link I need to replace, but it looks like you removed the tie rod end B.J. also when I planned on unscrewing the link from the turn buckle instead since the tie rod BJ's are ok.
I have the nuts turned one slot loose with cotter pins back in hoping a little more PB blaster gets in there while driving around town.
Old May 28, 2013 | 03:39 PM
tabijan's Avatar
tabijan
Autozone lends tools at no charge. You pay for the tool and get a refund when you bring it back in decent shape. The tools are generally better quality than what they offer for sale on the floor.
This type of separator is good if you can get the fixed jaw into place -
Note that the nut is still loosely in place so the parts that come loose don't smack you in the face.
Harbor Freight used to sell a set for cheap enough that you wouldn't mind taking the fixed jaw to a grinding wheel so it fits. I don't see it on their website today.
Sixto
93 E150 Chateau 5.8 185K miles
Old May 28, 2013 | 08:00 PM
rebar13's Avatar
rebar13
You know, I called all over and could only find the pitman puller. Even though my steering box is so far up there I cant even get the puller on.. I bought it for $15
Where can I buy the puller you have in the pic? Nice.
Old May 28, 2013 | 08:52 PM
tabijan's Avatar
tabijan
This is one option - 22mm Universal Ball Joint Tie Rod End Separator Remover Puller | eBay
This is another - Ball Joint Separator Tool 19mm Benz VW BMW Etc | eBay - since E150 tie rod ends are the size of passenger car ball joints.
Sixto
Old May 28, 2013 | 09:18 PM
rebar13's Avatar
rebar13
Sixto
I don't have any problem spending a few bucks on pullers.. But how do I know if any of those fit my E350?
I might be better off buying a few locally so I can return the ones that dont fit easy.
Old May 28, 2013 | 09:30 PM
tabijan's Avatar
tabijan
This didn't show in searches for 'ball joint' but it might do the job - 3/4" Forged Ball Point Joint Separator . There's a Harbor Freight store in Cedar Rapids. Mind HF tools are typically of dubious quality. If you like it, wait for a sale and buy 3 or 4 more :/
Sixto
joelgator
Mar 1, 2005 01:30 PM
joelgator
Feb 27, 2005 10:22 PM
fordxxx
Sep 22, 2004 02:07 PM
Cornelius
Sep 23, 2003 03:22 PM
Ken2600
May 5, 2003 09:07 AM
