289 HiPo exhaust manifolds?
There is s ton of room on the engine compartment of these trucks. You can run just about anything that you want. EB owners use these manifolds but have not found much of a gain with them. Matter of fact, most Small block owners use a similar manifold and those came on 350W engines. Almost identical in flow to the hi po SB manifolds.
Those manifolds bring some decent money from mustang guys.
Why not sell them and install a quality set of headers? More power to be made with them.
Surely you are not after a restoration type thing, since these trucks never had thismanifold, so I assume that some additional flow is the desire.
That being said, you cant beat the flow of a properly designed header.
heak even a poorly designed header will flow better than just about any manifold.
MikePacey
02-04-2015 01:57 PM
old farmer
12-10-2014 04:53 PM
Alan93Bronco
12-12-2004 06:55 AM
