6.0L Injector replacement????
Old Sep 21, 2009 | 11:07 AM
miller6670's Avatar
miller6670
I have a '05 F-250 w/6.0 and I have a bad #4 injector...I pulled the injector and it has a lot of carbon build up. My question is should I replace all the injectors or just replace the one that has failed...My instincts tell me to replace them all since the truck has over 150000 miles, but my wallet says just the one...lol. Any help would be greatly appreciated!
James
Old Sep 21, 2009 | 11:15 AM
npccpartsman's Avatar
npccpartsman
Since you can do it yourself, then do them one at a time. If it was a dealership thing and you had to keep going back then I'd say do them all. two small tips. Make sure the cylinder isn't full of diesel fuel from pulling the injector and get the oil out of the injector clamp hold down bolt hole. I use a q-tip for the hole and crank the truck over for the diesel in the cylinder.
Old Sep 22, 2009 | 06:16 AM
miller6670's Avatar
miller6670
Thanks man, I appreciate the input...I think that's the direction I will go.
Old Sep 24, 2009 | 05:55 PM
Big Angry Hillbilly's Avatar
Big Angry Hillbilly
Make sure you torque the injector properly.
Big Angry Hillbilly
Also - why did the injector fail?
Almost all the6.0 fuel injector failures are due to low/negative fuel pressure.
Old Sep 24, 2009 | 09:26 PM
300rwhp's Avatar
300rwhp
what do you mean low pressure I have lost 4 injectors on my early build 03 in the last 6 months. It happened in two groups and so all 8 have now been replaced.
But if I have a fuel pressure problem that is contributing what can i do ?
Old Sep 24, 2009 | 09:37 PM
bismic's Avatar
bismic
With low fuel pressure, it is common to have the right side injectors go first (passenger side).
Old Sep 24, 2009 | 09:53 PM
300rwhp's Avatar
300rwhp
well that happened in my experience, it went right bank (2 went but replaced 4) now my left bank went (6,8 went replaced all 4) I am diligent about replacing my fuel filters
Old Sep 24, 2009 | 10:39 PM
bismic's Avatar
bismic
Any performance mods (tuning)? Do you use OEM filters? How often are they changed?
Old Sep 24, 2009 | 11:02 PM
300rwhp's Avatar
300rwhp
fuel filters OEM changed every 20000 kms
Oil filters OEM changed every 7500 kms
no mods
invintive
Jan 28, 2017 10:35 PM
holdendaniels
Mar 20, 2016 06:04 PM
mkingz
Dec 16, 2015 03:46 PM
catman52987
Jan 29, 2012 10:37 PM
thedaddycat
Feb 11, 2010 10:41 AM
