compressor wheel...
Old Sep 20, 2009 | 07:52 PM
PsD007.3's Avatar
PsD007.3
compressor wheel...
dont really have the money for a new turbo or anything and i was lookin to eliminate my surge problem what is the absolute best wheel on the market for my truck?? i heard of whicked wheels but never really heard of anything else..
Old Sep 20, 2009 | 07:54 PM
Izzy351's Avatar
Izzy351
That's all there is. It's just the early 99 wheel, and all the fancy marketing names refer to the same one. Pick one that's in stock and at a decent price. Check with Clay at Riff-Raff Diesel...
Old Sep 20, 2009 | 07:56 PM
PsD007.3's Avatar
PsD007.3
i seen extreme diesel power website that they have one for like $75..soo far the cheapest i found are all the wheels pretty much all the same?? or is there different ones..and is it worth putting a new wheel in?? like will i notice any difference at all??
http://www.xtremediesel.com/product-...px?product=260
Old Sep 20, 2009 | 07:59 PM
Izzy351's Avatar
Izzy351
They're all exactly the same. Make sure they're in stock at that place, and call Clay -- see if he can hook you up...
Old Sep 20, 2009 | 08:02 PM
PsD007.3's Avatar
PsD007.3
http://www.xtremediesel.com/product-...uct=260..thats what i found clay has his listed at $99...willl i notice a difference at all?? it surges when i got my superchips turned on hi-performace setting when i'm on the throttle real hard...
Old Sep 20, 2009 | 08:11 PM
Izzy351's Avatar
Izzy351
Just check with them and make sure they're in stock -- I've heard they don't have them all the time.
Old Sep 20, 2009 | 08:13 PM
PsD007.3's Avatar
PsD007.3
ok and is the upgrade worth the $75?? will i notice any performance difference?
Old Sep 20, 2009 | 08:18 PM
triskit16's Avatar
triskit16
Joe is right. I contacted them before I was given mine, and they weren't expecting a delivery for almost a month. I have some good connections myself, and they're not the easiest things to get a hold of sometimes.
As far as the surge...it takes care of a lot of peoples surge issues, but it wont eliminate the worst cases. No performance gains, just eliminates surge and lets out a heck of a nice whistle...
Old Sep 20, 2009 | 08:20 PM
megawatt00's Avatar
megawatt00
You won't notice any performance difference it will eliminate the sure that happens from time to time. I installed on this past August and the biggest that I noticed is that it whistles more especially with having stacks on my truck. I noticed how pronounced it was last week when my brother borrowed my truck and I heard him drive off. Turns some heads for sure.
Old Sep 20, 2009 | 08:24 PM
PsD007.3's Avatar
PsD007.3
sounds like i'll be checkin one thanx alot guys i'll check back with you when i get it put on i'll call XDP and clay tomorrow
Old Jan 19, 2010 | 09:01 PM
Kajtek1's Avatar
Kajtek1
Now can somebody give a really clear answer about real life difference between compressor wheels?
I checked that all compressor wheels for 7.3 are interchangeable for 1994-2003. The only reported difference I see repeated several times is, that wicked wheel gets rid of the surge.
Than I found a post from guy who put his truck on dyno and after replacing stock wheel with wicked one his HP drop by 12.
I know 12 hp might be the test error, but makes you thinking, doesn't it?
I have early 99 model that originally has wicked wheel and I was satisfied with it, but than have no comparison. Now the wheel got blown by the dealer (I made a topic about incident) and I have to get a new one.
Bottom line, the wicked wheel run for close to $100, while late 99 wheels are on ebay for $35. I drive mostly freeways and power surge is not really my concern.
Old Jan 19, 2010 | 09:23 PM
Ziggy.'s Avatar
Ziggy.
A real clear answer? the "wicked wheel" design wheel actually flows a bit less air than the factory wheel, that is how it eliminates the surge. The only other thing you can do to help eliminate surge is to get a ported compressor housing, that is why you dont really have that issue on most aftermarket turbos, because they come standard with ported housings.
Old Jan 19, 2010 | 10:01 PM
Kajtek1's Avatar
Kajtek1
Originally Posted by Ziggy.
A real clear answer? the "wicked wheel" design wheel actually flows a bit less air than the factory wheel, that is how it eliminates the surge. .
I think that was the answer I was looking for.
Thanks
Old Jan 19, 2010 | 10:03 PM
Kwikkordead's Avatar
Kwikkordead
It will make a huge difference.
My turbo would surge on stock tune, pulling the trailer.
The wicked wheel completely eliminated the surge when towing.
I can MAKE it surge, but the EGT's spike to 1400+. So for all practical purposes the WW will "cure" your surging.
Old Jan 19, 2010 | 11:11 PM
Ziggy.'s Avatar
Ziggy.
Well said Dan, its not really about what you performance you can gain above stock in terms of airflow, its about keeping the performance of the turbo that you would be losing otherwise. Kinda of like purposely taking one step back to take 2 steps forward.
