Lost 65 Rear Brake Parts. Need Advise
Went to put my brake system back together, and it looks like some parts got lost over the winter and during painting.. who knows.
I need to find replacement parking brake levers for the rear drums. What other year of truck will work for a 65 F100. Also the equalizer assembly for connection of the cables to the rear drums is not to be found. Same question as above.
Does anyone sell these parts?
Thanks
Thanks
C3SZ2A637A .. Right Parking Brake Lever / Obsolete
No Ford Dealer or obsolete parts vendor has any.
C3SZ2A638A .. Left Parking Brake Lever / Obsolete
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675. This dealer is HIGH BUCK!
No other Ford Dealer or obsolete parts vendor has any.
Both these levers fit:
1964/67 F100 / 1966/75 Bronco with 11" rear brakes / 1963/66 Thunderbird.
1963/64 Galaxie / 1970/71 LTD with 11" x 2 1/2" rear brakes.
The parking brake equalizer is the part the two rear cables attach to.
C3TZ2768A .. Parking Brake Equalizer-Includes the Adjustment Rod / Obsolete
Fits: 1963/64 F100 w/a 114" Wheelbase only / 1965 F100 2WD only / 1963/64 Econoline.
Contact FTE member camperspecial65. He may have some/all of these parts.
FTE members Garbz2 and Bill W may also be able to help you.
on
You can get a bag of hardware (springs and nails) at Napa or any other parts supplier. Specific items like those P-Brake arms require a trip to the junk yard. Some of the hot rod suppliers sell an 11 inch drum system for Ford nine inch rears that has everything all new including the backing plate. Sometimes that is the least expensive way in both time and money. 11 inch drum rear brakes coupled with disks in front are a really good system.
AFAIK, the following three parts were Ford Dealer items only.
What does the 9" rear axle have to do with what brake parts were installed?
It has nothing to do with it...at all.
1961/72 right & left F100 Park Brake levers:
1961/63: C1SS2A637A & C1SS2A638A.
1964/67 F100: C3SZ2A637A & C3SZ2A638A
1968/72 F100: C5AZ2A637A & C5AZ2A638A (also fits: 1973/77 F100 & 1975/77 F150).
If the above part numbers were all the same, the parts would all be the same.
Are the part numbers the same? No they are not the same...as y'all can plainly see.
maestro1024
10-02-2014 07:03 PM
RRHD
11-06-2011 10:11 AM
Trog59
07-10-2010 08:39 PM
Lightningotis
02-01-2004 10:58 AM
