please help!!!!2 day old 1995 f150 and having problems
i just got this truck 2 days ago for work that is 25 miles one way 95 f150 4x4 ex-cab 5.8l......question is i was towing a flat trailer tonight and i noticed like the truck was feeling like it was going over a a bunch of bumps or hopping sorta. my dad said put in 4 wheel drive (its a 4 wheel on the fly by the way) so i put it on 4 wheel and it was still kinda of doing and it started clicking in the front end i was doing 35mph the whole time we got where we were gong unloaded the trailer went back and the noise was still coming from the front end and the 4 wheel drive was off and still felt like like was going over bumps or hopping.... so did i destroy my 4 wheel drive or front end or something else and how much will it cost at a shop to fix it ? please help!!!!! by the way i have no i have no towing knowledge ever
Never engage 4X4 on dry pavement. If it has not disengaged try backing up for about 10 feet with the wheels straight.
The bumpy hops may be a bad tire. Or a bent rim, axle, etc. COuld be busted wheel lugs as well as loose lug nuts.
DO a visual, pull and tug.
itires are fine i really dont think it was doing it when i put on the brakes
The clicking noise is probably your auto lockers. And if they are clicking they need replaced. I recommend Manual Lockers, they are much stronger.
so everything is fine but still have the clicking in the front end when the 4 wheel drive is on. i was testing it out the other day just moving back in foward in my drive way my dad said it might be the half shaft on the driver side is bad....does that sound liek it could be that problem?
