Rattle when I feather throttle?
Old Sep 18, 2009 | 11:21 AM
jrobbins1982's Avatar
jrobbins1982
Wondering if someone can help me. I have a 2005 f-150 with the 5.4L and there is a rattle in the top passenger side of the engine when I feather the throttle. That is the only time it does it consistently. I have also heard a very loud knocking while the truck is under strain while in drive and reverse. It sounds like a hammer on sheet metal. Any ideas?
Old Sep 18, 2009 | 04:48 PM
Oldguy4's Avatar
Oldguy4
The rattle from the passenger side sounds like the old cam phaser noise these engines have. But the loud knocking while under a strain? Where does it sound like it's comming form? engine or underneath?
Old Sep 18, 2009 | 08:09 PM
garyle's Avatar
garyle
What type of oil and filter are you using?
Old Sep 18, 2009 | 09:00 PM
pb34's Avatar
pb34
It may be an exhaust manifold leak. I had a ticking noise coming from the passenger side wheel well that I had under strain and it was there constantly but more prominent in overdrive. I thought it was the cam phaser but I brought it in and turns out it was the exhaust leak. Sounds fine now!
Old Sep 20, 2009 | 06:50 PM
jrobbins1982
I am using Motor Craft oil and filter. Both noises sound like they are coming from the same place. I was thinking it was the cam phasers also but it is not making that diesel noise at idle.
Old Sep 20, 2009 | 07:34 PM
garyle's Avatar
garyle
Something to try. Get some crankcase flush and flush your oil system. Do this twice if you have the time and $$$$$. Do both the oil and filter. Add some top shelf synthetic oil and a new Motocraft filter and check the noise again. Pay close attention to your filters and run your oil through a screen when you drain it. Look for pieces of metal and rubber(from a bad filter).
I just trashed a 05 5.4 by using an aftermarket filter. The upper end on the passenger side was rapping loudly due to a plugged oil port. I flushed it and the filter was loaded with metal and pieces of rubber. Refilled with Royal Purple and a Motocraft filter and all is quiet.....For now. Running on borrowed time now until the damaged parts give up....
Old Sep 21, 2009 | 08:22 AM
jrobbins1982
That is good advice. I did use a cheaper filter once or twice. I will try it when the rain stops here in GA. I will let you know how things go. Thanks
Powerstrokin7.3L
Oct 20, 2012 04:39 AM
magneto259
1983 - 2012 Ranger & B-Series
15
Jan 14, 2012 01:56 PM
richdavis69
Dec 29, 2011 04:12 PM
boggerted
Mar 8, 2007 09:19 AM
GeneStoner
Dec 18, 2004 07:45 PM
