F250 cold starting problem
Old Mar 7, 2007 | 07:13 PM
boggerted's Avatar
boggerted
I have a 1989 Ford f250 custon auto 2wd that seems to be having a throttle problem. If its cold, when you try to start it, it only starts if you feather the gas and once it catches, you hold the gas for a little bit until it warms up. The check engine light is on, and i replaced the IAC valve since i thought that was the problem. What should it do?
Old Mar 7, 2007 | 07:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
the first thing to do is have the codes read to find out why the CEL is on.
Old Mar 8, 2007 | 07:46 AM
boggerted's Avatar
boggerted
Is there a plug for the code reader? I have the reader but can find where it plugs in.
Old Mar 8, 2007 | 07:56 AM
classicfordfreak's Avatar
classicfordfreak
Usually the plug is under the hood i believe on the driver side fender near the air box. Usually it has a plastic cover over the plug that says diagnosis on it or something of the sort.
Old Mar 8, 2007 | 09:19 AM
tjc transport
i ain't rite
the test port is under the hood, on the driver side fender, between the brake master and wheel.in this picture, you can see what the test port looks like.
timeld
Nov 11, 2014 01:14 PM
florida-alex
Nov 15, 2012 06:53 PM
ATC_250SX
Jan 25, 2005 09:22 PM
Mestrell
Jul 22, 2004 10:23 AM
Rickster45
Jun 3, 2004 09:52 AM
