lift pumps
Old Sep 16, 2009 | 05:44 PM
u.f.o's Avatar
u.f.o
lift pumps
Anybody know how many differrent lift pumps used on 7.3s? I went to change mine differrent arm shape and lengh
Old Sep 16, 2009 | 06:12 PM
joe f350's Avatar
joe f350
dont use the long arm
Old Sep 16, 2009 | 06:47 PM
u.f.o's Avatar
u.f.o
Thats what came out of the engine, can i use the shorter more bent arm pump
Old Sep 16, 2009 | 06:56 PM
joe f350's Avatar
joe f350
i have the short curved on but i have a 6.9 u have a 7.3 ask dave s he will know for shure
Old Sep 16, 2009 | 07:16 PM
u.f.o's Avatar
u.f.o
Hey Dave whats the differrents?
Old Sep 16, 2009 | 07:44 PM
Ironman03R's Avatar
Ironman03R
The difference is the "long" arm one was replaced by the "bent" looking one, I cant tell you why but you cant get the "long" ones anymore.
Old Sep 16, 2009 | 07:56 PM
u.f.o's Avatar
u.f.o
Steve that will be great if it fits!
Old Sep 16, 2009 | 09:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The deal with the straight arm versus the bent arm.
When installing the straight arm lift pump you must roll the engine over till the low spot on the drive cam can be seen with an inspection mirror.
Failure to do so can cause lift pump failure, the arm to break off and fall in the oil pan, possible engine damage if it hits something else on the way down like the crank shaft.
Both pumps will work just fine as long as they are installed correctly.
I just bought a bent arm lift pump at NAPA last winter.
They have both and the box has the same number for both.
Old Sep 17, 2009 | 04:19 AM
u.f.o's Avatar
u.f.o
Thanks Dave I thought I had gotten the wrong one . Thanks Frank
Old Sep 17, 2009 | 07:18 AM
Ironman03R's Avatar
Ironman03R
I wasnt aware that they still made the old style ones, all I've ever seen for aftermarket was the new style. Good to know!
Old Sep 17, 2009 | 08:52 PM
Dave Sponaugle
I am not going to say that they are still making the old style.
Given the amount of inventory NAPA has here at the distribution center, that may have been a 10 year old inventory item.
I just know the item numbers are the same, you only know which one you have when you open the box.
Old Nov 18, 2009 | 06:05 PM
ctann's Avatar
ctann
The deal with the straight arm versus the bent arm...
Hi Dave,
I just ordered a Bosch Pump (looks like it wasn't just my heater o-rings that were causing my woes ). If I get the "bent-arm" style, does that mean I can skip the step with the mirror, and rotating the engine?
Thanks,
Chris.
LAblover324
Feb 15, 2017 08:13 PM
mikeinmilton
Feb 10, 2013 07:25 AM
mtgrzlyman
Feb 3, 2006 02:19 PM
gbrett
Mar 5, 2005 03:16 PM
LC39B
Jan 1, 2005 07:11 PM
