Sponsored by: Innova
alarm wiring
Old Sep 29, 2009 | 06:14 PM
ReAX's Avatar
ReAX
The blue wire on the 7p connector is the input for the doors. It needs to see (-) when the door is opened. You can double check, but the dome light wire should be 12v+ all the time, but get a ground when you open the door (completing the circuit and lighting the bulb). You can use the wire from the dome light to the doors to connect to the alarm as the trigger. I'm not sure if the door lamps work on the same principal, but it's plausible.
RJG1987
Jul 8, 2017 07:27 AM
reptar0077
Jan 20, 2017 08:43 PM
nullop
Nov 30, 2016 09:57 PM
Kevgsp
2009 - 2014 F150
Feb 24, 2010 10:08 PM
Ford Fx4
2004 - 2008 F150
Nov 18, 2007 08:51 PM
