multiple codes on 96 f150
Old Sep 15, 2009 | 07:40 PM
44dwarf's Avatar
44dwarf
I got multiple codes this weekend on my 96 f150 with 302.
early in the day i got the normal 402 i get every time i start the truck. I've replaced the DPFE several times and that fixes it for a few weeks long enough to get it to pass inspection..
Anyway later in the day i got 1150, 1151 and 1152 all at the same time.
Cleared those and an hour latter got 153.
Any ideas?
Thanks
44
Old Sep 15, 2009 | 08:09 PM
danr1's Avatar
danr1
P0402 Exhaust Gas Recirculation Flow Excessive Detected
No real reason replacing the DPFE corrects that, likely not the problem. Fault not corrected and just takes a while to return is more likely the reason it thinking it does. Has to happen more then once, and within a given amount of key off on cycles.
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P0153 02 Sensor Circuit Slow Response Bank 2 Sensor 1
Some insight to these codes/faults should be apparent by watching the O2 sensors and the fuel trim in action.
Information here on how to interpret the O2 sensors readout if you do not know how > http://www.aa1car.com/library/o2sensor.htm
Being familiar with your diagnostic scan tool/code reader helps too......
Old Sep 16, 2009 | 10:44 AM
44dwarf's Avatar
44dwarf
All i've got is a reader i can't watch engine functions in real time.
I know the 402 is a known 96 FORD ishue infact they come with a paper saying the sensor range is difrent then the OEM spec but ford recomends not to flash the ECM...
the 1150-52 have got me cross eyed as they happend at the same time. lean and rich so i can only figure the O2's on that side are on there way out or something else is wrong like maybe the begining of an exhaust leak? hung injector etc.
Was hoping someone else had seen this before.
Thanks for the link!
44
FordYoungGun35
18
Jan 25, 2013 10:08 AM
tawneekay
21
Dec 16, 2011 04:13 PM
holiday187
2004 - 2008 F150
Aug 16, 2007 11:52 AM
mgcardinal
1997 - 2003 F150
Oct 18, 2006 09:59 PM
FghtinIrshNvrDie
15
Apr 28, 2005 07:23 PM
