Engine build
Old Jan 20, 2013 | 01:03 AM
FordYoungGun35's Avatar
FordYoungGun35
Engine build
Okay so I've got my old 5.0 out of my 96 f150 it was a mass air motor.. I've got multiple options and I need to know whether or not to keep the old motor and just save the block and build on it. Or just save up $ and buy a crate motor.. It will be driven often.. Won't really see mud often mostly street.
Would I want to consider going carbourated?
If I keep the old 302 block and just bore it to a 306 or get a stroker kit?
Old Jan 20, 2013 | 02:05 AM
88n94's Avatar
88n94
I would forget the crate motor, they don't seem to have a very good reputation. I would find a local shop with a good reputation that rebuilds engines and have them rebuild your old engine.
Kind of sounds like you want a little more power. Boring your block to a 306 won't gain any noticeable power, it will just even up the taper on the cylinder walls for hopefully longer ring and engine life. Personally I don't like stroker kits, I feel it will hurts reliability. If you want more power, I would consider going to a 351.
I would keep the fuel injection and forget the carburetor. All the above just my opinion of course.
Old Jan 20, 2013 | 02:31 AM
Evan_P's Avatar
Evan_P
Between a crate motor and having your block redone, that really comes down to the current condition of your engine right now. What exactly do you want out of the truck. Just a simple street truck? Or do you want a tire shredder? I thing a full free flowing exhaust, headers, cam and head upgrade on your 302 would be a great setup honestly. That is of course after you get the block off to the machine shop. Pair that with some 4.11 gears. Then there's option B, 351 swap. Build up a 351 with the same upgrades and have an even better street beast. For the tire shredder route, look for a 351, turn it into a 393 or 408 stroker and tune the EEC. That would be quiet a machine.
I honestly wouldn't bother with a stroker due to them not being as durable as a normal motor. I would go with your block if its salvageable, bore it to 306 so the walls are even, and do the upgrades I listed above. That's my recommendation.
P.S. Why do you keep making new threads all on the same topic?
Old Jan 20, 2013 | 10:31 AM
FordYoungGun35
Well the block needs bored but it is usable.. heres what parts I'm thinking of and tell me if there compatible.. I don't wanna go ordering all of these and something not fit or these parts not work together and have a bunch of paper weights..
Cam- COMP Cams Xtreme Energy Camshafts 35-320-8 - Mobile SummitRacing.com
Intake- Edelbrock Performer 5.0 EFI Truck Intake Manifolds 3841 - Mobile SummitRacing.com
Heads- Ford Racing 302/351W Turbo Swirl Aluminum Cylinder Heads M-6049-X306 - Mobile SummitRacing.com
Headers- Hedman Street Hedders 89350 - Mobile SummitRacing.com
Rocker arms- Crane Energizer Pedestal Mount Roller Rocker Arms 44746-16 - Mobile SummitRacing.com
Fuel injectors- Trick Flow® TFX
I do appologize for the new threads but I guess I wanted to have one final thread now that I have my old block out and ready to be built on..
Old Jan 21, 2013 | 05:37 PM
FordYoungGun35
any ideas??
Old Jan 23, 2013 | 11:36 PM
Nally427's Avatar
Nally427
i would rebuild the 5.0 i did that and i havent looked back. i built it with comps 31-255-5, a set of 1.7 crane rockers, gt40 heads, longtube headers with flowmaster 44s, and a new trac lock differential with 4.10 gears. of course i had good wires and plugs and other little things but help it run that much better, but for power, its awesome, puts stock trucks to shame.
Old Jan 24, 2013 | 07:50 AM
Puddy's Avatar
Puddy
Love the FRPP X306 block, great flowing and now I want more haha
Old Jan 24, 2013 | 09:11 AM
FordYoungGun35
is the edelbrock intake necessary or could i just use the stock truck intake or even the intake from a HO motor
Old Jan 24, 2013 | 09:16 AM
Conanski's Avatar
Conanski
Yes use the stock truck intake and with the money you save get a Moates Quarterhorse, Binary Editor software, and a wideband O2 sensor to tune your engine.
Old Jan 24, 2013 | 09:40 AM
FordYoungGun35
Will I need to get any machine work done to the intake? The block is getting bored 30 or 40
Old Jan 24, 2013 | 09:49 AM
Conanski's Avatar
Conanski
No machine work necessary but it wouldn't hurt to do a little port matching of the lower intake to those heads.
Old Jan 24, 2013 | 09:54 AM
FordYoungGun35
Both the lower and upper intake look like they have some black buildup so I didn't know if porting would be necessary.. So will those headers match t heads
Old Jan 24, 2013 | 04:31 PM
Evan_P's Avatar
Evan_P
If there is a buildup of crud in the intake, take them to the machine shop and have them clean them. They will be able to get all of that out.
Old Jan 24, 2013 | 10:54 PM
FordYoungGun35
Do those headers work with those heads
Old Jan 25, 2013 | 09:46 AM
tbolt64's Avatar
tbolt64
My .02 is put a used 351 in it (hey its already bigger than a 347, right?) get the y pipe from a junkyard truck with a 351. Get on Craigslist and get a set of GT40 heads(not the p heads), some pacesetter shorty headers headers from Summit. The cam you like looks good, and you have a good cheap build that will make plenty of street usable power and torque.
