11 psi boost
Old Sep 12, 2009 | 04:10 AM
roushcm's Avatar
roushcm
so when i check the up pipes can i take off the wraping on the driver side up pipe? also do i check it when its idleing or do i have to pull them off and check them?
Old Sep 12, 2009 | 06:10 AM
greedy737's Avatar
greedy737
The uppipes are your exhaust pipes coming up to the back of your turbo! Check for soot around the dounts!!
Old Sep 12, 2009 | 07:36 AM
roushcm's Avatar
roushcm
ok i will check them today and let you know what i find out. i was also thinking of getting a boost gauge insted of using my tuner.
Old Sep 13, 2009 | 12:13 PM
roushcm's Avatar
roushcm
well i just got done with a test drive after i put a new autometer boost gauge in and it was reading 21psi of boost on my stock setting! my edge was reading 11. It must not be reading right, i belive the autometer now. Also thanks to everyone who was trying to help me.
Old Sep 13, 2009 | 12:35 PM
orng1's Avatar
orng1
Way better but your stock is 21? Where did you get a boost source from? I t'ed the map sensor line, what did you use?
Old Sep 13, 2009 | 02:36 PM
MR5x5's Avatar
MR5x5
The edge tuner reads the PCM signal right off the comm bus. It is what the PCM is being told the pressure is. While the mechanical gage may well be correct, I'd be suspicious of your MAP sensor providing false readings. If the MAP reading is off, it is going to create other problems in the fueling tables. I'd start by checking the hose to the map sensor for cracks or leaks.
Old Sep 13, 2009 | 04:55 PM
roushcm's Avatar
roushcm
I tied it into the map sensor line i think it is the one that goes from the intake over by the oil filler cap and it plugs into a electrical thing on the passenger side of the truck.
Old Sep 13, 2009 | 05:08 PM
Izzy351's Avatar
Izzy351
That's correct. If you don't have a boosht fooler, your MAP sensor is bad. Mine was reading very low until I adjusted my fooler regulator. Now it reads correct up to 21psi.
Old Sep 13, 2009 | 05:48 PM
roushcm's Avatar
roushcm
i dont know what your talking about, fooler regulator? are you saying i need to replace my map sensor? could this hurt my 7.3? on the tow setting it is reading around 25 psi on the autometer and still 11 psi on the edge.
Old Sep 13, 2009 | 05:52 PM
Izzy351's Avatar
Izzy351
It's possible it's hurting economy or power. If the PCM thinks you're only getting 11psi, it might not fuel normally. It won't HURT the engine as in break something.
Boost fooler is for when you have a chip that can make over 25psi. With the stock setup, the PCM sets a code around 22psi and will defuel the engine at 25. I can get to 30 now since the PCM is held to seeing 22 max. It's just an air pressure regulator put inline with the MAP line. You put the gauge tee before it (or in the spider) so the gauge sees the real pressure.
You can see it in this pic on the far left side. Notice I have an AIH delete plug tapped for a fitting for the boost reading:
EDIT: Here is where I got mine:
http://www.itpdiesel.com/store.php/products/Overboost
Old Sep 13, 2009 | 06:16 PM
roushcm's Avatar
roushcm
ok thanks for the pic and the info.
