Modular V10 (6.8l)
ABS-Vehicle speed sensor problems
Old Sep 10, 2009 | 04:34 PM
markvii91's Avatar
markvii91
Sorry this might be long, but it's worth reading! Problem day 1- Aftermarket trailer brake controler thinks there is a trailer hooked up, but no trailer. Problem day 2- ABS light intermittent, when off ABS activated like truck is on ice! Problem day 3- Speedo and fuel gauge irratic! Problem day 4- no tail or license lights- burned out headlamp switch! By this time I'm ready to put a bomb under her! Finally I start at rear where trailer wire hooks up working to front of truck. Removed every wiring connector, be carefull they may be brittle. At driver's side frame rail below front and rear doors, there are three large connectors. When I pulled mine apart, there was a boat load of water that came out! I blew them out with air, cleaned with PB Blaster, blew air again, put on DiElectric grease, put them together and voila! all problems solved! First I thought ABS sensor, Then maybe Vehicle speed sensor, It didn't spit out any codes! All it was, was water! Hope this helps anyone with similar problems!
Old Sep 10, 2009 | 11:44 PM
3000 FPS's Avatar
3000 FPS
Was the truck in deep water?
Old Sep 12, 2009 | 02:44 AM
markvii91's Avatar
markvii91
Yes, we've had a lot of rain here in northern Ohio. I work in steel mills and industrial plants with dirt roads and deep puddles!
Fusion7.3
May 29, 2014 02:35 PM
ROKNZRX
May 18, 2005 10:13 AM
alan35
1983 - 2012 Ranger & B-Series
Jul 1, 2004 12:19 PM
momo
Feb 5, 2004 06:41 AM
