oil pan?
Old Sep 9, 2009 | 11:58 PM
dieselkid's Avatar
dieselkid
oil pan?
how in sam hill do u take this beast off?? i thought it was bucket shaped but no, it goes all the way up to the pull??? wonce u get all the bolts off does it just come off easy or wut? wut all do i need to take off to get this off
Old Sep 10, 2009 | 12:46 AM
Brimmstone's Avatar
Brimmstone
Pull the engine. The oil pump is holding you back
Old Sep 10, 2009 | 10:15 AM
PLC7.3's Avatar
PLC7.3
In essence you need to drop the oil pump. Why are you removing it ............
Old Sep 13, 2009 | 09:18 PM
dieselkid's Avatar
dieselkid
i keep hearing a knock on start up and i think some of the drip stick broke off, not quite sure... but i just read it could be a leaky fuel injector...
now im 17 almost 18 and i know never to start a car that got a knocking unless u know it wont destroy the engine. so i wonce i hear that knocking i didnt know forsure wut it was a towed that truck home from school... but i now think its the injectors, im not goign to go to all that trouble to pull the oil pan. i thought it was more like like cars that it pulls off easy... ill check the oil for metal frag, im almost surtan now there r none, stickign new oil in tomorrow after school and going to forget the knock and starting that thing up thats guys
Old Sep 14, 2009 | 02:11 AM
Brimmstone's Avatar
Brimmstone
Be careful still if it's a leaking injector. I've seen the top of a piston eaten off because of that.
Old Sep 14, 2009 | 04:01 AM
79f150toy's Avatar
79f150toy
Really??? ooops...I guess I should replace mine, but mine only seems like an intermittent knock..it runs well and then some days it has a knock/ping...
Old Sep 14, 2009 | 08:54 AM
Brimmstone's Avatar
Brimmstone
With the engine running loosen the injector lines at the injectors one at a time with a wrench preferably a line wrench. Tighten each line back up before going to the next. You'll probably come to a cylinder which when the line is loosen the noise will go away. Of course an intermittent knock could also be that the engine has a bad wrist pin which has been known to happen. Dave S could probably give you a better idea though
dieselkid
Dec 15, 2010 04:07 PM
dieselkid
36
Mar 6, 2010 09:23 PM
matejcekautoworks
Feb 1, 2009 07:10 PM
1972ford_f-100
15
Jun 20, 2006 04:33 PM
1972ford_f-100
Feb 16, 2004 11:19 AM
