getting rid......of
Old Jun 14, 2006 | 09:30 PM
1972ford_f-100's Avatar
1972ford_f-100
Smile getting rid......of
ok,well this may stir up the kettle with some one,but i want to get rid of everything computer controlled,i want a old style 300 six,no computers,wut do i have to do to get rid of it all,wut years work for parts,wut years do i have to use,wut wholes do i have to plug to get rid of the air pump,but i still want an egr just cause it will help me in gas wise
any help would be great,thx all
Old Jun 15, 2006 | 09:48 AM
Kemicalburns's Avatar
Kemicalburns
what rig? year? whats wrong with it currently to make you go backwards?
Old Jun 15, 2006 | 03:01 PM
1972ford_f-100
1984 f150 4x4 4.9l tfi eecIV i just want less problems and an esier way of fixing and cheaper way so in the future if something wrong happens with the ignition or fuel,it will be way esier to diognoss it ya'know?
Old Jun 15, 2006 | 04:36 PM
sharpster68's Avatar
sharpster68
Sell it and get a pre 75 model easy fix and in my opinion you geta better truck
Old Jun 16, 2006 | 08:53 PM
63redtudor's Avatar
63redtudor
Probably the best thing you can do is to switch the ignition to the duraspark 2 (DS2). This system is easily found on ford vehicles from about '75 to '83 or so. You'll need the distributor, harness & module. Everything except the harness can be found off the shelf at most automotive stores. Ask for parts for a '79 300. Supposedly you could still get the connections from ford & make your own harness (don't know for certain on that one). Or you can pull everything off of a truck in a junk yard. Check the ford six site (www.fordsix.com) as one of the guys there wrote a very nice article on this procedure. Keep in mind that this is for the smaller ford six, but it should be a great guide. Due to the fact that you have an '84 (like mine), you might be able to simply 'plug & play' as the connections might still be there (some '84s had the DS2).
If you replace the ignition system, you might as well replace the carb. The TFI system is called a feedback carb system (almost like a primative EFI) & the carb won't work all that well with the older distributor. To keep it simple you can just simply get a carter YF from the early '70s. You could also look into a 2 or 4-bbl carb, but that will take some mods, or a different intake.
Those 2 things should help out quite a bit. Good luck.
Edwin
Old Jun 16, 2006 | 10:24 PM
1972ford_f-100
well,i have a 72,which im selling(wink wink,lol) but i got this new truck cause it was 4x4,but wut do i throw out,and how do i keep the egr?
Old Jun 17, 2006 | 08:16 AM
1972ford_f-100
ok,wut do i do with all the wires goin to the curent coil nad soes this truck already hava a resister wire?
Old Jun 17, 2006 | 11:59 PM
1972ford_f-100
hello,help,anyone?
Old Jun 18, 2006 | 10:56 AM
Country705's Avatar
Country705
I totally disagree with that statement i think that the 80 - 86 trucks are just as good as the 73-79 ford trucks. plus lets not forget ITS FORD MADE its gonna last forever either way
Old Jun 18, 2006 | 11:13 AM
1972ford_f-100
hey lets not start a pissing match i still need my questions asked
Old Jun 18, 2006 | 12:23 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
well you can convert the ignition to a duraspark 2. u need the distributor, module, wiring and duraspark 2 coil. the tfi coil wont work with the duraspark conversion. i had that problem on my 86 mustang i did the same swap. i hate computer controlls on those carbed engines. they might have been nice when they were new, but with age they deteriorate and the older much simpler and easier to fix (and cheaper) duraspark swap is a great thing to do. i believe the egr can be hooked up to ported vacuum to open the valve. they probably have a ecm controlled solenoid controling it stock. if u have a mixture controll solonoid on the carb then u should change it to an older non eec carb. you will need to hook up the older distributors vacuum advance line so u have vacuum advance. i had problems with my eec 4 to duraspark 2 conversion with the white wire coming out of the module. with it hooked up like the stock wiring diagram the engine didnt turn off with the key, so i left it unhooked. this should be a straightforward conversion as long as u find a donor truck with all the parts. u might wanna check on the coil resistor i dont no if they use the same one. good luck.
Old Jun 18, 2006 | 07:33 PM
1972ford_f-100
how do i pull out all the wires,do i just cut off the wire pack that goes through the fire wall to the ecm or is this a bad desicion?thx oldfordtrucksrule
Old Jun 19, 2006 | 08:56 PM
oldfordtrucksrule
well u could unplug the ecm, that way u dont have to cut anything. funny i didnt read 63 redtudor's reply until after i posted mine, it was almost exactly like mine lol. i wouldnt cut any wire bundles just to be safe. once u undo the wiring to the eec4 ignition and carb, the ecm isnt really doing anything. i would just leave the ecm in place but unhook all power leads to it.
Old Jun 19, 2006 | 10:30 PM
plowpusher's Avatar
plowpusher
I've done this mod on an 84 f150 300 six and a 83 with 351w. First all the cumputer stuff is in the same harness unplug the ecm seperate the harness from the truck you can unplug every thing just pull it out get a ds2 distributor from an earlier model ( I used the stuff from an 81) both the trucks I did had a ignition module on the fender with two wires comming from the firewall from the ignition switch on wire has 12 volts when the key is in the start position the othe has 7.5 with the key in the run position.Get a ds2 module, there is a great picture of the ds2 system in the 73-79 forum right now.If you can't find a harness for the module to the distributor you can make one its only four wires I used a trailer light harness and connectors. Use an earlier carb. Plug yuor egr into a coolant controled vacum switch and ported vacum and you'er done good luck
Old Jun 19, 2006 | 10:36 PM
plowpusher's Avatar
plowpusher
the thread in the 73 to 79 forum is titled 77 f250 distributor wiring
