Please help name this part
Old Sep 9, 2009 | 09:55 PM
krejci.mike's Avatar
krejci.mike
I developed a fuel leak a couple of days ago and I narrowed it down to this rubber coupling in the picture below. The part is inside the red circle and the blue X is the fuel filter housing for reference. It is the small rubber hose that connects the steel drain line to the rear of the valve body.
I need to know where I can buy it asap as I have a duct tape fix there now.
Thanks!
Old Sep 9, 2009 | 09:58 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
That is the fuel bowl drain, and connect the spout to the hardline that runs around the valley to where it dumps under the engine. I doubt that it is your leak though, more likely it is your o-rings in the drain spout.
Old Sep 9, 2009 | 09:59 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Im not sure what it is called,but can't you just replace it with another small rubber hose?
Old Sep 9, 2009 | 10:01 PM
big poppa's Avatar
big poppa
Maybe just an fuel bowl drain valve kit from Guzzle would do it.
Old Sep 9, 2009 | 10:44 PM
danskool's Avatar
danskool
Go Bills !
15 minute fix. Had this link bookmarked just for information on the valve. If the valve wasn't leaking then there would be no need for the hose at all. (only for draining water/fuel . For maintenance) I forgot to put my little hose back on until I figured it out when i drained the housing to install a new fuel filter. I wonder why that little hose was on my shelf for almost 3 months.
http://home.centurytel.net/sabre/drainvalve.html
Old Sep 9, 2009 | 10:49 PM
Riffraff Diesel
PREMIUM SPONSOR
You can give this a try also.
http://www.riffraffdiesel.com/category/F97-03-O.html
Old Sep 9, 2009 | 11:53 PM
Izzy351's Avatar
Izzy351
I would name it "Fred".
Get the O-ring kit. I'm 99.93% sure that's your problem.
Old Sep 10, 2009 | 12:01 AM
krejci.mike
Ok thanks for all the help guys, I will get that kit. Joe, what about the other .07%?
Old Sep 10, 2009 | 12:03 AM
Izzy351's Avatar
Izzy351
There's a 0.07% chance that it's coming from somewhere else.
Old Sep 10, 2009 | 12:18 AM
Riffraff Diesel
PREMIUM SPONSOR
Or is that .07% that its name isn't Fred
teamlx88
Jun 15, 2014 07:48 PM
f2504x4man
Jul 27, 2013 04:25 PM
'87F-2504X4
18
Feb 6, 2011 12:12 PM
Iversen-fords
Jan 17, 2009 06:11 PM
